It is currently Wed Jul 02, 2025 8:44 am
 Post subject: floor leaking...
PostPosted: Wed Oct 05, 2005 9:46 pm
what can i do? its a late model clubby so...yeah. so how can i solve this problem? i plugged up all the holes but it just keeps coming!!!
78 Leyland Mini - Prince
PostPosted: Wed Oct 05, 2005 9:57 pm
Sure it's the floor?
Usually wet carpet is from a leaking windscreen :wink:
PostPosted: Wed Oct 05, 2005 10:21 pm
its only the real carpet. im pretty sure its the leaky floor, but i know the drivers side rear window is hvaing issues, after a bit of rain i noticed theres water in the buckety thingy. new window seal? theres also a bit there someone has bogged it up? could this be the problem?
PostPosted: Wed Oct 05, 2005 10:40 pm
Windscreen & windows are the problem 99 times out of 100 !
Carpets are wet in the morning when you haven't been driving?
Windows :wink:
Fix that seal!
PostPosted: Wed Oct 05, 2005 11:02 pm
And i'll bet that it all fogs up real quick when it rains, too?
Leaky windows, buddy :wink:
OR just wait until you get so much water down there that it rusts out and plain drains itself out.
PostPosted: Thu Oct 06, 2005 5:06 pm
In a mini its not only about stoping the water from coming in, but about stoping it from staying - if water leaks in you want it to drain away quickly = no rust - So check the drainage holes at the bottoms of the door pockets - some fools plug them up - open them - oh and check your windscreen wipers and bonnet insulation - water sometimes comes in through the wiper holes if the plastic bezels are cracked and through a badly fitting bonnet and runs down the heater hose cutouts and down the firewall onto the carpets.
PostPosted: Thu Oct 06, 2005 5:39 pm
if your car is sittng on a slope when it leaks (usually window seals ) the water will run wherever. my car had a leaky front window and it was facing up a hill so in the morning only the back carpet would be wet
PostPosted: Thu Oct 06, 2005 6:32 pm
yep they are all right, seals. mine does the same thing!!! :evil:
PostPosted: Fri Oct 07, 2005 5:25 pm
if you have the time take out your carpet and your seats, and then get someone to hose your car while you sit inside with everything closed etc... squirt at every window and you will notice quick smart where water is coming from. I had the same problem, replaced all the seals, replaced all the plugs in the floor, then realised that when i did this, water was coming in over the back of the bonnet and dripping down behind the speedo into the cabin....!!!! (its a roundnose) New rubber across there and it stopped.
Users browsing this forum: No registered users and 53 guests
