stepped drums
https://www.ausmini.com/forums/viewtopic.php?f=2&t=11919
Author:  manofaus [ Fri Oct 07, 2005 8:04 pm ]
Post subject:  stepped drums
how much do stepped drums offset your wheels?
Do you need longer wheel studs or is there a different flange?
Do clubman flanges (rear to suit stepped drums) fit a roundnose?
thanks
Author:  Curly [ Fri Oct 07, 2005 8:51 pm ]
1. They don't offset your wheels, they increase your track by the width of the step on each drum. If I recall correctly, the Cooper 'S' ones are about 3/4" on each drum so that makes the track 1.5" wider.
2.Yes - longer studs, they fit into the standard hub flange.
3. Yes.
Author:  drmini in aust [ Fri Oct 07, 2005 11:03 pm ]
Big wheel Moke drums are 3/4" wider, Cooper S Or Clubby S ones are 1"... as I found when I bought a Moke one by mistake once. :cry:
Author:  Spaceboy [ Fri Oct 07, 2005 11:36 pm ]
it's an easy job to change them over, did it myself with just a BFH and some screwdrivers.
Author:  coops [ Sat Oct 08, 2005 2:04 am ]
I got moke ones and only found out their 1/4" smaller after I got them machined and linnings to suit and to make it worse it would of been cheaper to buy new cooper S ones and linnings :oops:
Doc do you reckon the moke ones will be ok as the front will have drooper S brakes?
Author:  drmini in aust [ Sat Oct 08, 2005 7:00 am ]
Depends what wheels you use at front. S steel wheels will foul. LS offset Contessas will foul. :cry:
Mini offset Contessas, Hotwires, or Jellybeans will clear. :D
Author:  lobby69 [ Sat Oct 08, 2005 12:44 pm ]
hey ive got 2 sets of 1" steped drums, came on the clubby that i stripped, was stoked when i saw them,
1 pair going on the rear of the van!
