WHY!! is my mini leakin again! =(
https://www.ausmini.com/forums/viewtopic.php?f=2&t=1192
Author:  ryan23 [ Sat Jul 17, 2004 9:41 pm ]
Post subject:  WHY!! is my mini leakin again! =(
i had changed the rocker cover gasket and tightened the bolt till i cant turn no more!!!
took the car for a long drive - abt 2 hours - came back n parked in my garaged
and the next day (b4 i left for brisbane), i did a check and found no oil stain! woohoo so i wave goodbye to my mini thinkin what a good job ive done! :lol:
but then when i returned earilier today (few days later) - again i took my mini for a little ride...just round the corner...and this time i found her drippin on the left handside of the car. AHHHH....
:cry: :cry: :cry:
Author:  PhildoD [ Sat Jul 17, 2004 10:40 pm ]
Okey dokey, a common mistake made with the cork rocker cover gaskets is overtightening them.
The cork will shrink a bit over time, and ya just tighten then up a nip every so often. Tightening it all the way up straight away doesnt necessarily mean it will stop it leaking.
I used to cheat with my old V8, by using a bead of Permatex Ultra-Copper and just lightly squeezing it down till it cured, then give it a tweak more. The rocker covers on that were a PITA since they would warp and leak all the time.
Author:  ryan23 [ Sat Jul 17, 2004 11:28 pm ]
oh no...so what should i do now?...loosen the screws?...and replace again with a gasket?...or just let it pee pee every now n then....
Author:  drmini in aust [ Sun Jul 18, 2004 7:01 am ]
More likely not the rocker cover gasket this time- probably the timing cover seal, or LH diff cover seal.
Clean the whole motor with degreaser, rinse it off, go for a 15 min run, then jack it up and look under. You should be able to see where it's coming out of. :wink:
