my bore
https://www.ausmini.com/forums/viewtopic.php?f=2&t=11932
Author:  lobby69 [ Sat Oct 08, 2005 12:29 pm ]
Post subject:  my bore
hey fellas, i just took the head off my 1100 to go into the van to have a look at the bores,
ontop of the pistons it has 040.... imguessing that its taken out 40 thou???
on the bores i can still see the criss cross marks from the wire brush after it was bored................ this a good sign to a good condition bore??? there are no gouges in the bores either,
i have no clue to when it was bored out and no information on the motor itself,
any other ways to tell if itgs in good nick without striping the block down?
blake
:wink: :wink: :wink:
Author:  awdmoke [ Sat Oct 08, 2005 2:46 pm ]
Measure the bores if you have verniers,
or if you don't, look for a "lip" at the top of the bores. If the bores are badly worn there will be a discernable lip where the piston doesn't run quite to the top of the block.
Sounds like you have a good one but :D
Author:  lobby69 [ Sat Oct 08, 2005 6:47 pm ]
im sure its a fresh rebuild or one with low k's, im stoked that i got a good one,
saves me quite a bit of dosh now that i dont have to fork out money for a rebore and pistons,
what is ann 1100 plus 40 thou in cc's? is it 1172???
:wink: blake
Author:  danidad [ Sat Oct 08, 2005 7:33 pm ]
bonus for sure .. if its still got hone marks and no other obvious damage then its probably a good fresh motor.. cheering
Author:  Mini Mad [ Sun Oct 09, 2005 1:26 am ]
+0.40 is 1132 i think ;)
Author:  lobby69 [ Sun Oct 09, 2005 3:05 pm ]
[quote="danidad"]bonus for sure .. if its still got hone marks and no other obvious damage then its probably a good fresh motor.. cheering[/quote
woohoo, im stocked, brings forward the super charger,
1132, i can live with that,
blake :wink:
Author:  min13k [ Sun Oct 09, 2005 9:31 pm ]
i think thats what they call cross hatching ???
lobby i'd just throw a set of bearing in and mabe a set of rings in if it has been sitting a while
makka
