It is currently Sun Jul 27, 2025 3:31 pm
 Post subject: Door rusting
PostPosted: Sun Oct 09, 2005 6:27 pm
I just noticed two slight lumps appearing in the middle of the drivers door.. I know for a fact that when it rains water gets down the window into the door (the inside door cards have been damp a few times).. So theres a big chance it would be rust.. What is the best way to go about fixing this? If I remove the door and take the door cards out, will I be able to get to where the rust is easily?
I need new window rubbers.. :cry:
PostPosted: Mon Oct 10, 2005 9:35 am
hmmm easily - there's a word they did not use when designing the mini :lol:
there is an inside steel panel, and window winding mechanism in between the door card and the outer skin, so no it will not be easy. BUT i would still remove the door card, because you want to fix it once and properly.
