It is currently Thu Aug 07, 2025 5:40 am
PostPosted: Fri Oct 07, 2005 7:28 pm
So got some discs and it seems as though the swivel hub is rubbing
against the rotor and its not turning properly/ at all
any ideas at all??
PostPosted: Fri Oct 07, 2005 7:45 pm
Check your PMs in a sec.
PostPosted: Fri Oct 07, 2005 7:49 pm
what discs, what swivel hubs? pics?
PostPosted: Fri Oct 07, 2005 7:51 pm
I'm guessing 7.5s with 8.4 uprights.
PostPosted: Fri Oct 07, 2005 8:52 pm
any ideas at all??
Man that sucks. after paying 950 for them "ready to go" :? :shock:
PostPosted: Fri Oct 07, 2005 10:34 pm
All disc swivel hubs (except metro) are basically the same..
Depends who made the rotors. Some aftermarket 7.5" ones are known to rub on the outer part of hubs, others do not.
Just machine a little bit off the outside diameter of the hub, near the end. Some hubs have this done already. :wink:
PostPosted: Fri Oct 07, 2005 10:58 pm
7.5 hubs are slighty different to the 8.4 hubs at the end just grind it away abit to fit the disc on
PostPosted: Sat Oct 08, 2005 2:18 am
thanks guys for the help!
so where ezacly does it need to be ground away??
just the end point??
Thanks to Big willy and Steve for all the help also,
much appreciated ; )
PostPosted: Sat Oct 08, 2005 6:57 am
Yes it's the last 5mm usually. Won't need much off at all. Put some chalk or paint on it there, fit disc onto CV and spin it. 1mm probably is all it will need off. :wink:
PostPosted: Sat Oct 08, 2005 2:40 pm
ok, so i dnt have a lathe or whatever is needed to do this...how can
i fix this problem at home? Ive been out to GR's but he was closed.
Any ideas? this really needs to be done this weekend
PostPosted: Sat Oct 08, 2005 5:16 pm
Grab a case of crown larger and head to Kev's place :P :lol:
PostPosted: Sat Oct 08, 2005 6:01 pm
no worries, its all done now.
they are spinning freely!!!
YAY
thanks for all the help guys!
PostPosted: Sat Oct 08, 2005 7:23 pm
:D Great to hear. 8)
PostPosted: Mon Oct 10, 2005 6:03 pm
Damn right..!!! haha.
Hey Big willy... you ever gonna shoot me some pics of my car..??
:wink:
PostPosted: Mon Oct 10, 2005 10:05 pm
Yeah been busy... flipped car and all :lol:
Hopefully i'll whip round to the warehouse tomorrow and grab some piccies.
8)
