It is currently Sat Aug 02, 2025 12:42 pm
 Post subject: Short Shifter Question
PostPosted: Mon Oct 10, 2005 1:41 pm
Is insttalling a short shifter any good? I heard it gets rid of the pull to reverse but you might accidentally get into reverse if your going to 4th gear, not good for freeways.
PostPosted: Mon Oct 10, 2005 1:44 pm
I don't think you'd get from third to reverse. Apart from having to lift it, divert direction, it also won't destroy the gearbox anyway.
The effort required to change gear is also increased.
PostPosted: Mon Oct 10, 2005 1:51 pm
Are you talking about the standard shifter or the short shifter?
I didn't think you could 'accidentally' get into reverse while driving with a short shifter but so I've been told you can. Are these any good anyway?
PostPosted: Mon Oct 10, 2005 1:54 pm
Could be because I'm used to 5 gears & sometimes accidentally get into 5th opps.
PostPosted: Mon Oct 10, 2005 1:56 pm
The short shifter makes it harder to change gears because you have less leverage in it.
You have the same chance for getting into reverse with a short as you do with a long: not much when moving.
I don't think there's a definite "they are good" or "they are bad", it's just personal preference.
PostPosted: Mon Oct 10, 2005 4:12 pm
resident alien
resident alien
Just cut your current stick shorter... mine was done by the PO.
PostPosted: Mon Oct 10, 2005 7:34 pm
yea i cut mine abit shorter, i dont think it is possible to go from 3 to R accidentally
