Battery Safety Issue https://www.ausmini.com/forums/viewtopic.php?f=2&t=12106 |
Author: | awdmoke [ Thu Oct 13, 2005 2:26 pm ] |
Post subject: | Battery Safety Issue |
dansedgli wrote: I I received a "worked" 998cc engine and box from my uncle which was apparantly in perfect nic before his tyre iron fell across his battery terminals and lit his mini on fire.
![]() ... and I have previously told the tale of my sisters mini having a fuel tin roll over the battery & ignite ![]() PLEASE FIT A SECURE COVER OVER YOUR BATTERY ![]() |
Author: | gibovski [ Thu Oct 13, 2005 2:38 pm ] |
A mini I owned but had sold later managed to weld the jack to the floor of the boot. No real carnage though. ![]() |
Author: | deleted [ Thu Oct 13, 2005 3:50 pm ] |
My boot has seen flames. |
Author: | drmini in aust [ Thu Oct 13, 2005 4:58 pm ] |
Mini Mad welded the jack across the battery terminals at a chicane down the road here. Bit of fire but not bad. He got home, but battery was rooted... ![]() |
Author: | 9YaTaH [ Thu Oct 13, 2005 6:06 pm ] |
Post subject: | Me Too |
Scene: Dreary black rainy night, heavy traffic, fast lane of three, out side Bankstown Aerodrome. Suddenly everything goes black/no engine. Somehow every one misses me as I glide over to the kerbside. Thinking it is battery I immediately open boot, YIKES ![]() ![]() Smoke rising off jack neatly welded across both terminals ![]() Grab the warm jack and pull ![]() ![]() Widen stance and wrench jack off terminals...lights come on ![]() Be careful people ![]() |
Author: | Angusdog [ Thu Oct 13, 2005 7:10 pm ] |
After reading on here about the guy refitting his 2nd (right hand) tank, touching the terminals and the whole garage going up in flames, I made a plywood shelf covering the spare wheel and battery. Makes it tidier and easier to load as well as safe. |
Author: | Namibian CAMEL [ Thu Oct 13, 2005 8:27 pm ] |
Before the existance of Mike ![]() http://www.ausmini.com/forums/viewtopic ... light=fire A wire coat hanger was floating in the boot, 1st day of 'permanant' working for me, when i drove mini everyday, Contacted battery terminals and was off ![]() ![]() ![]() the blackness is still on the boot insides , i havent even scrubbed it, 10 months and more, ![]() ![]() I didnt realise until 6 months or so later that it had put a fairly decent melt mark in the battery ![]() ![]() right now i read Gafs comments and the answers are ype chuckin water on, the batt melted ![]() ![]() SO im asking for it again ![]() ![]() ![]() I think i cover it good enough though, so its alright ![]() |
Author: | steamer [ Thu Oct 13, 2005 8:33 pm ] |
agreed putting a mdf cover in the boot was the best thing ive done in a while much nicer ![]() |
Author: | drmini in aust [ Thu Oct 13, 2005 9:18 pm ] |
If you can't be bothered making something up or getting the proper `predigested cardboard' cover, at least chuck a piece of carpet in there. Works for me... ![]() |
Author: | NAV [ Thu Oct 13, 2005 10:24 pm ] |
You could make a cover. Or just get a van and you will never have to worry about that sort of thing ever cause it has its own built in battery cover ![]() ![]() ![]() ![]() |
Author: | J_A_M [ Fri Oct 14, 2005 8:40 am ] |
for a couple of bux you can buy condoms for your terminals...like 99% of new cars have fitted standard. |
