It is currently Sat Aug 16, 2025 2:00 pm
 Post subject: Weber Box + Speedo Mount
PostPosted: Sat Oct 15, 2005 6:03 pm
Okay so i've got my 45DCOE, and the deluxe.
Previous doodle has attempted to cut the firewall to clear a weber/dello before, so i might as well finish it and turn it into a proper box.
I can easily get one made, or just buy an 'off the shelf' item.
The thing that worries me now is where i mount the speedo.
I'd love to retain the original centre mount, but what do i mount it to?
Any advice appreciated.
Big willy.
PostPosted: Sat Oct 15, 2005 6:07 pm
put clubby gauges in :idea:
make a box.. easy as....
PostPosted: Sat Oct 15, 2005 8:25 pm
its a morrie not a leyland so it has to be kept original. :)
PostPosted: Sat Oct 15, 2005 10:31 pm
1. Don't make that box too wide.
2. Use a Mini-K 3 clock binnacle, but screw it thru the trim on the dash. This way you can put MDF or similar packing behind the trim as required to get speedo & binnacle where you want it.
Lengthen the wiring so you can undo the binnacle and move it into the car- makes gauge maintenance nice & easy. Watch the oil pressure line... don't kink it.
3. Find a 90* angled speedo cable drive box. Gets cable out of the way.
I believe a Range Rover (or was it Land Rover?) one fits according to a previous post here by someone..
If Mini cable is too short now, use an early screw-on Clubby one or a Morris 1100 one.
:wink:
PostPosted: Sun Oct 16, 2005 12:47 am
good call doc, willie made it clear what he wants to do with the car and I agree!
The poor little tyke has been good the last few months, lets pretend he never spammed the forum.
Noli Illegitimi Carborundum
PostPosted: Sun Oct 16, 2005 7:08 am
Modified battery box?? I've heard you can do something with that.
Let me know how you go. I'll want to do something like this in the near future. PIC's PLEASE!!
Good to hear you're mini-ing again. Just keep it on 4 wheels this time!!! :P
Bob Slattery
PostPosted: Sun Oct 16, 2005 7:28 am
i am just about to finish making one for gafmo..
not hard to do.. if you hunt around the net you will find differend sizes.. i got my size from avonbar's weber box. 1.5mm thick sheet cut to shape. on the the metel bender.. the seam weld with the mig..
Can use a batt box... and just cut it back to how deap you want it.. but then folding the tabs back out may be tricky unless you got a good small magna-bend..
Will have Jims done the next few days.. so will post pics when done. :wink:
PostPosted: Sun Oct 16, 2005 7:29 pm
Cody... good stuff. I'll have to look into the measurements.
Others: :lol: I'll try sticking to mostly Mini related posts from now on.
And constructive ones, at that.
With lots of pics.
And progress reports.
Even if you DO get sick of them, i'll still do them... i'm sure someone is watching the project take shape 8)
PostPosted: Sun Oct 16, 2005 7:38 pm
the right top one is the weber box..
Weber airbox.We have now increased the size of this unit so that it will accept either Split Weber DCOE'S or a single DCOE with cold air system. 400mm long 170mm high 150mm deep
Product of avonbar racing :wink: [/img]
PostPosted: Sun Oct 16, 2005 8:12 pm
Don't tell Will to put Clubman guages in, tell him to put Rover ones in, he likes Rovers better. :lol: :lol: :lol:
PostPosted: Sun Oct 16, 2005 8:13 pm
So those Weber air boxes are pretty much an 'over-the-counter' item from Avonbar Racing?
Sounds good to me if they are... saves rooting around 8)
PostPosted: Sun Oct 16, 2005 8:15 pm
And yep, Rover gauges are class (the Cooper ones only), but i don't want to put dash rails in it.
I'm going the 'resto-mod' route... a fair whack of original Morrie gear (seats, dash, tail lights, flares), but some nice touches of my own (Mk 1 S flares, my 12" Charcoal superlites, 45weber :lol: , etc)
PostPosted: Mon Oct 17, 2005 1:44 am
HAHA I was thinking that..
And will yes. thats a over the counter part. around 45 pounds of the top of my head..
www.avonbar.co.uk then click on turbo bits on the left..
O FARK.. more free advert... :shock:
PostPosted: Mon Oct 17, 2005 8:42 am
400mm is way too long, if you want to keep the centre binnacle..
BTW the 1968 UK works rally cars had split Webers, mounted onto a MK2 S twin HS4 manifold. The Weber carbs' flanges were not stock though. And I believe they had no `Weber box' in the cars, either. :wink:
There are pics on the web, somewhere..
PostPosted: Mon Oct 17, 2005 8:45 am
yeah.. but you just change that mesurement like I did.. :lol: but its a good pic and size guide to make you own.. :wink:
