Rear carpet installation
https://www.ausmini.com/forums/viewtopic.php?f=2&t=12257
Author:  deleted [ Mon Oct 17, 2005 7:42 pm ]
Post subject:  Rear carpet installation
Hi,
What is the best way to cut the carpet at the rear to allow it to slide under the seat support (how should it be done!) You could cut a chunk out, slit it once and then again at a right angle?
Author:  NoMoreMinis [ Mon Oct 17, 2005 7:47 pm ]
I'd slot it in a 'T' shape.....so that it hugs that centre bit when it's all in......
Jeremy
Author:  Dylans Clubby [ Mon Oct 17, 2005 7:48 pm ]
i cut a hole where the post goes, nice tight fit, then make an incision below the main aorta... i mean make an incision form your fresh new hole to the back of the carpet. you may want to edge it properly or something, i didnt and its not falling apart, but i can't imagine it being a bad idea.
also you will need to cut a hole for your rear seat mounts, im not sure whether the new carpets cme whit this or not though.
also seat belt clips and handbrake
Author:  deleted [ Mon Oct 17, 2005 8:07 pm ]
rear seat mounts?
what rear seat mounts?!!
Thanks for replies btw, T thing soundeth good.
Author:  Dylans Clubby [ Mon Oct 17, 2005 8:29 pm ]
oh sorry i meant the front seat mounts (but they are at the bcak of the front seats... :oops:
