Block skimming https://www.ausmini.com/forums/viewtopic.php?f=2&t=12299 |
Page 1 of 2 |
Author: | K-Bar [ Tue Oct 18, 2005 11:37 pm ] |
Post subject: | Block skimming |
what are the reasons for this??? to raise compression?? to make sure the face is flat?? if i did this, wouldnt my pistons rise slightly above the blocks surface.. well thats how it looks for mine.. is that ok if i was going to use a 12G295? 1100 block and pistons. thanks. kaden. |
Author: | willy [ Tue Oct 18, 2005 11:38 pm ] |
Sometimes it is to true the block. usually always. For C/R raising, the head is usually shaved to piss, flat tops, etc. |
Author: | poeee [ Tue Oct 18, 2005 11:42 pm ] |
It's used to get them flat. Usually the case with Mini engines is that after a while and some blown head gaskets, between the cylinders erodes a little, causing it to blow head gaskets more often. This has happened to Rodney, even after a head reco. When rebuilding an engine, it is stupid not to get it shaved flat. If it wasn't done and causes a problem, then the engine needs full pulling down. You usually don't take enough off the block for the pistons to poke above. |
Author: | K-Bar [ Wed Oct 19, 2005 12:07 am ] |
ahhhh ok....fair enough. price range for this to be done?? seems like a pricey thing to do.. |
Author: | poeee [ Wed Oct 19, 2005 12:16 am ] |
I would be guessing the same price as getting the head skimmed. ![]() |
Author: | willy [ Wed Oct 19, 2005 12:20 am ] |
Head skim = $40 Use that as a guide ![]() |
Author: | drmini in aust [ Wed Oct 19, 2005 6:43 am ] |
Takes a little more work to clamp block up before machining. I usually charge $50 for Mini blocks... ![]() |
Author: | manofaus [ Wed Oct 19, 2005 7:55 am ] |
Motor builders like to deck the block to make sure that the head is square to the cylinders as well. Usually done when you open up the bore. |
Author: | J_A_M [ Wed Oct 19, 2005 10:19 am ] |
my engine machinist wanted $50 to do mine. I didn't get it done. |
Author: | drmini in aust [ Wed Oct 19, 2005 4:42 pm ] |
Bad JAM. Bad....BAD!! ![]() ![]() ![]() ![]() |
Author: | 64morris [ Wed Oct 19, 2005 5:14 pm ] |
just make sure you ask them not to machine the tab where the engine no. is... i had my new engine all built up and put it, got the car home and when i went for mod plate for the seats the guy asks where my engine no. was ![]() i wont tell you how i got by that one... ![]() |
Author: | drmini in aust [ Wed Oct 19, 2005 5:26 pm ] |
64morris wrote: just make sure you ask them not to machine the tab where the engine no. is...
i had my new engine all built up and put it, got the car home and when i went for mod plate for the seats the guy asks where my engine no. was ![]() i wont tell you how i got by that one... ![]() Yeah I NEVER take that pad off. But most shops don't give a stuff..."deck it sir? No problem..." ![]() |
Author: | awdmoke [ Wed Oct 19, 2005 5:41 pm ] |
i had my new engine all built up and put it, got the car home and when i went for mod plate for the seats the guy asks where my engine no. was ![]() i wont tell you how i got by that one... ![]() Magic Marker? ![]() |
Author: | 64morris [ Wed Oct 19, 2005 8:42 pm ] |
close enough ![]() |
Author: | Rodney [ Fri Oct 21, 2005 10:00 am ] |
I'm getting a block skimmed as we speak. Get it back next week for engine rebuild so will tell you the price when i pick it up. Cheers |
