cheers for all the help guys
spent some time on the engine today, figured out the wiring for the coil thanks Morris 1100, primed the fuel pump like the doc said, gave the old girl a few sniffs of petrol down the carb and she started first go. Also, to my suprise, she ran smooth and quite and revved nicely, not bad for an engine that hasnt been run in god knows how long.
Only now ive got a new problem
I think there more petrol leaking out of the carby then there is going into the engine
it seems to be coming from the top of the float bowl (which is missing a screw so was expected) and also from the spring arm coming out of the bottom of the bowl. Im guessing a rebuild kit would supply all the necessary gaskets and parts to fix this?
Once again thanks for all ya help and keep it comin as im still a long way off havin a drivable mini (altho i havent ever driven one yet so i dont know what im missin)
PS check the members gallery in the next couple of days for an update on the progress, with pics, of my Deluxe project
