It is currently Wed Jul 23, 2025 10:06 am
PostPosted: Mon Oct 24, 2005 7:10 pm
Ok put my mini in to get a check up... turns out the dude that i brought the mini from (ausmini member but wont mention who) didnt put the right rockers in.... got a 1330 in it wit like 850 rockers?
when i asked him if they ment to be offset over the springs he said yes... but no they arent... they missin the washers or whatever to line it up properly... so like i need new rockers cuz my old ones are (a) not right ones (b) wearing away
does anyone have any rockers i can purchase? am lookin for 1.5 ratio but 1.3 or anything that will get my mini goin fine again will do?
pls pls pls help... thnx
PostPosted: Mon Oct 24, 2005 8:50 pm
High heel ninja
Where are you located for a start??????? Try Karcraft,minisport,mini spares they wil be able to help you, a set of 1275 standard rockers would get you out of trouble.
Doogie
 Post subject: .
PostPosted: Tue Oct 25, 2005 7:48 am
hmmm sorry new login name... i live in blacktown in sydney
my mini is at mini spares and repairs in castle hill at the moment
and i cant get it back till i get the rockers fixed so i need some quick
ill try callin them places today to see what they got... thankz
PostPosted: Tue Oct 25, 2005 2:07 pm
C'mon then new guy at mini spares is bound to have a set of pressed steel oval pad rockers. they willl get you going for next to no money at all -then you can start thinking about spending the 350+ dollars on 1.5 ratio rockers. Just avoid the sintered steel rockers off an A+ mini.
PostPosted: Tue Oct 25, 2005 3:19 pm
The sintered steel of an A+ Do you mean the big chunky squarish ones - Why be wary of them ?????
PostPosted: Tue Oct 25, 2005 3:39 pm
High heel ninja
Hi Mike, good to see you finally made it on here.
Doogie
PostPosted: Tue Oct 25, 2005 3:45 pm
Been here a while now - maybe a month or two - just dont comment much
PostPosted: Tue Oct 25, 2005 3:46 pm
They're not as strong from memory the ordinary pressed steel ones are OK
Roads need more corners
