It is currently Fri Jul 25, 2025 11:01 am
PostPosted: Tue Oct 25, 2005 6:47 am
Since I want to sort out the squeaky front suspension on our 850, I'm planning to replace the knuckles. Are they all the same? And is it as seemingly simple (apart from corrosion issues) as the Haynes manual makes it seem? Letting down the hydro, popping the knuckles out, pop new ones in and pump up the suspension again? If so, I'll start sorting out that hydro pump, although there's a suspension place with the correct pump, which may be easier.
TIA :wink:
PostPosted: Tue Oct 25, 2005 9:55 am
I found the rears a bit interesting, in my case I had the rear arms off and so I could connect in the knuckle joint and then slide the arm into place, this seemed easier than doing it with the arm bolted up :wink:
Roads need more corners
PostPosted: Tue Oct 25, 2005 10:03 am
From what I've gathered over time...
A. Yes.
B. Yes....although "simple" is rather a subjective term when it comes to minis. Getting th cups out never seemed so "simple" as Haynes might suggest.
C. Yes. But just make sure everything is seated correctly before you pump it up again.
PostPosted: Tue Oct 25, 2005 10:22 am
Thanks Peddro - that's enough info to get the wheels in motion. Off to source some knuckles.
PostPosted: Tue Oct 25, 2005 11:58 am
I didn't think 850's came with hydro, was it changed out at some stage?
PostPosted: Tue Oct 25, 2005 12:07 pm
I doubt it's been converted. It's a '69 Mk II so almost certainly standard. Made in NZ so not an Aussie spec one.
PostPosted: Tue Oct 25, 2005 12:49 pm
Some 850s had hydro micky and steve's austin has it. :wink:
Users browsing this forum: Majestic-12 [Bot] and 83 guests
