POR15 https://www.ausmini.com/forums/viewtopic.php?f=2&t=12501 |
Author: | ddddave [ Tue Oct 25, 2005 12:45 pm ] |
Post subject: | POR15 |
Hi I'm in the process of removing rust from my van. Using POR15 product. But this is causing major headaches ![]() Problem is it doesn't seem to want to bond to anything. Not even the rust. Have used extensively but now can't feather out with sand paper without the POR just pealing up. At this stage it is really slowing things down as I'm basically sanding it ALL back off. Any one had the same experience? Any tips? Thanks Dave |
Author: | Steve [ Tue Oct 25, 2005 12:49 pm ] |
Have you washed of the marine clean or what ever it is before painting with the POR15 that may be the cause of the paint not sticking. Ring them and ask they are helpful people. Is yours the van with the checkered roof steve |
Author: | ddddave [ Tue Oct 25, 2005 1:03 pm ] |
I think I did all the steps properly. Just seems to me like the product itself is tougher than the adhesion to the surface. And yeah thats my van. No longer a checkered roof though. Roof will be yellow soon. ( Car crystal white ) Daffodil yellow or crystal primrose. Any comments on those colours welcome. cheers Dave |
Author: | 68matic [ Tue Oct 25, 2005 1:04 pm ] |
is it the van that got rust n dust? i must say it was one of the most disgusting vans ive seen... complete with missing window and garbage in the back... nice touch ![]() |
Author: | ddddave [ Tue Oct 25, 2005 2:01 pm ] |
yeah it won rust and dust You should see it now though Much worse ![]() |
Author: | 68matic [ Tue Oct 25, 2005 2:56 pm ] |
getting better ![]() |
Author: | feralsprint [ Tue Oct 25, 2005 3:46 pm ] |
I have never used the stuff but I think maybe you should just try a 2 pac highfill primer over it and then just rub the primer back, just try a small bit first as I think the pors is supposed to be left on and not rubbed |
Author: | gafmo [ Tue Oct 25, 2005 3:54 pm ] |
yer I would give them a call 1800 643 229..really helpfull guys did you use Marine Clean and Metal Ready and follow the steps using the warm water and all ![]() |
