It is currently Mon Aug 11, 2025 5:16 pm
 Post subject: getting out an 1100 auto
PostPosted: Wed Nov 02, 2005 1:57 pm
heya...
as Ive posted before, im looking at converting an auto to manual.
its in a morris 1100, but isnt the S :(
is there a way of getting out the engine without need to take out the transmision too?
Im new to the mechanics side of things, but have confidence i can do it. :shock:
just howwwww? :?
any info, no matter how small...
cheers.
1978 Leyland clubman S.
PostPosted: Wed Nov 02, 2005 4:13 pm
NO. You need to lift the lot out first.... :wink:
It's quite easy really, either with an engine hoist or a chain block.
A lifting bracket attached to the head helps a lot.
8)
PostPosted: Wed Nov 02, 2005 4:22 pm
lol, bumma.
so what bolts and things do i disconected. :lol:
i spose ill be needing a manual??
PostPosted: Wed Nov 02, 2005 5:29 pm
ok did this recent so hopefully i wont forget anything..if anyone spots something i missed please feel free to correct me...
disconnect battery...
exhaust (at flange if you dont intend removing manifolds separately)
wiring ( label it as you go, so if it takes a while being out , you will remember what wire went where)
I left radiator and hoses connected (lifts out as one complete unit)
universal or joints disconected to seperate diff from axles. (passenger side one is trickier, might have to semi remove wheel hub )
top engine steady.
gear linkages
speedo and carb cables....
4x engine mount bolts through subframe.
not necessarily in that order..
 Post subject: Mounts...
PostPosted: Wed Nov 02, 2005 5:42 pm
[quote="danidad"]ok did this recent so hopefully i wont forget anything..if anyone spots something i missed please feel free to correct me...
quote]
Morrie 1100s have three engine mounts...one is at the front and is a real 123456789 to get at the nuts.
PostPosted: Wed Nov 02, 2005 5:46 pm
cheers,,, getting mixed up with the mini :oops:
PostPosted: Wed Nov 02, 2005 7:28 pm
:) cheers guys.
very helpful
ill get onto it this weekend, then let you know how i went.
oh...also,
theres major damage near that front engine mount, so i think the grinder will be coming out to clear the metal away.
thanks..
kaden.
Users browsing this forum: No registered users and 209 guests
