It is currently Sun Jul 27, 2025 10:59 pm
 Post subject: Disc Pads..
PostPosted: Thu Oct 27, 2005 2:07 pm
Does anyone know if and where I can get a set of Bendix XP DB-815 disc pads from???
PostPosted: Thu Oct 27, 2005 6:21 pm
Don't most auto shops stock bendix i'm sure they can order them in in no time at all
PostPosted: Thu Oct 27, 2005 7:06 pm
The thing is, these are the older type pads that I am looking for that were made of that bad stuff.... :wink:
PostPosted: Fri Oct 28, 2005 11:56 am
Ok, what would be the best new type disc pad to put onto a Mini, something that does stop and not fade under heavy braking....
PostPosted: Fri Oct 28, 2005 12:02 pm
EBC Greenstuffs. They don't wear your discs either. :wink:
PostPosted: Fri Oct 28, 2005 1:40 pm
Thanks Doc. Just put new rotors on the Moke and the old fella that did the brakes doesn't like the new stuff (still likes the old forbidden pads :wink: ) but wanted to know what sort of pads other Mini owners used...
PostPosted: Fri Oct 28, 2005 3:28 pm
Greenstuffs are good enough to cope with track days. If you want something more bitey when cold and do mostly road driving, Blackstuffs (`Street Kevlar') may suit better. They are cheaper, too.
http://www.ebcbrakes.com.au/ click on `product range'. 8)
