It is currently Thu Aug 14, 2025 5:04 am
 Post subject: Brake booster
PostPosted: Sat Oct 29, 2005 8:00 pm
l purchased a reconditioned brake booster a few weeks ago. lt is supposed to be a vh44 model, But l think it may be a vh40. As there is no model sticker on the unit how can you tell the difference ? ls the booster cylinder diameters the same for both units ? If not what is the booster cylinder diameter of a vh44? This one measures 9 inches or 23cm. This includes the cylinder clamp ring.
http://photobucket.com/albums/v515/chasg/
PostPosted: Sun Oct 30, 2005 9:54 am
Google and ye shall findeth. Apparently you'll have to be quite light on the peddle.
A VH40 has a 9" diaphram housing and an output pressure of 1470psi........
A VH44 has a 7.5" diaphram housing and an output pressure of 820psi........
PostPosted: Sun Oct 30, 2005 4:46 pm
Thanks for the reply Mick. l had a feeling it was the vh40 instead of the vh44. Dont know if l will use it now. A vh40 booster with metro 4 pot callipers may be to touchy in the wet.
cheers chasg
PostPosted: Sun Oct 30, 2005 5:00 pm
Touchy?
You might flip the mini onto it's bonnet with four pots :D
PostPosted: Sun Oct 30, 2005 6:30 pm
if u dont want the vh40 ill buy it off you! :shock:
...seriously :!:
PM me if you are interested
PostPosted: Sun Oct 30, 2005 7:06 pm
If l do decide to sell it you will have the first option to buy siclad_5
Here is a photo of the unit.
PostPosted: Sun Oct 30, 2005 9:27 pm
Was that the one of eBay by any chance?
PostPosted: Sun Oct 30, 2005 9:55 pm
cheers :)
Users browsing this forum: No registered users and 278 guests
