removal of wiper regulator
https://www.ausmini.com/forums/viewtopic.php?f=2&t=12689
Author:  Brown Clubman [ Mon Oct 31, 2005 11:08 am ]
Post subject:  removal of wiper regulator
ok...so I've taken the wiper arms off, I've taken the two nuts off the wiper arm thingys ... I've removed the three small nuts securing the regulator to the fire wall ...... what next. I just can't seem to manouvre it right to get it out! What's the trick here? :x
Author:  aaron [ Mon Oct 31, 2005 12:09 pm ]
where are you located? i am in melbourne and can show you if you aren't too far away. Am down in the docklands.
Basically the trick is the spacers under neath need to be turned around. Do the drivers side one first pop it out and then do the passenger side one. It is even easier if you undo the motor from the slider. 4 small nuts on the front of the wiper. remove the face plate. then pop off the circlip holding the arm insde off.
Aaron
Author:  Brown Clubman [ Mon Oct 31, 2005 12:45 pm ]
Aaron
Arron - thanks for the offer mate :) I'm in Altona.
I'll give it another shot and will call on you if needed. By the sounds of it I should be right though. Will let you know how I go.
BC.
