Oil plug leak? https://www.ausmini.com/forums/viewtopic.php?f=2&t=12727 |
Author: | TimB [ Tue Nov 01, 2005 11:15 am ] |
Post subject: | Oil plug leak? |
Is oil leaking from the oil plug a standard mini problem? My plug has 2 aluminium washers that look stuffed, is this the standard washers. Anybody with any clues to fixing this, please help as I what to do an oil and filter change.javascript:emoticon(':)') |
Author: | Mick [ Tue Nov 01, 2005 11:19 am ] |
I presume you're talking about the sump plug. Just take the plug out, walk to Supercheap, Repco, Autobarn, Autopro, or whoever is around and get a new copper washer from the bolt stand. Comes in those little packets the bolts come in. Blackwoods would have them over the counter as well. Should cost less than a dollar. |
Author: | awdmoke [ Tue Nov 01, 2005 11:21 am ] |
I use a new copper washer every second oil change after that, they will usually leak |
Author: | TimB [ Tue Nov 01, 2005 6:00 pm ] |
Yes, the 'SUMP' plug, sorry mental blank! ![]() I was in a hurry when I posted cause I was going out and I thought one of you guys would have the answer by the time I got back and you did. Thanks heaps. ![]() |
Author: | benjamin [ Tue Nov 01, 2005 6:06 pm ] |
if it still leaks put some teflon tape on the thead i think maybe ![]() |
Author: | drmini in aust [ Tue Nov 01, 2005 6:39 pm ] |
Teflon tape is not a great idea... it can get in there and block things up. Our Clubby has a leaky sump plug `coz some deadbeat put a helicoil in, crooked... ![]() So whenever it needs a change now, I wipe the plug threads and put a couple of drops of Loctite 515 or 518 Master Gasket on them. No more leak... and it's still easy to remove. ![]() |
Author: | Gadgets mini [ Tue Nov 01, 2005 7:19 pm ] |
Tim B asked Is oil leaking from the oil plug a standard mini problem ![]() Reply No its only marking its territory ![]() |
