The head came back with a perfect report. Dead straight and all valves sealing perfectly.
The valve guides and valves came back well within tolerances. The stem seals were a little hard, but not excessively so. But while the head is off, I'll replace them anyway.
EDIT: Guides are confirmed as 1275 type cast iron ones.
The only thing I can think of now is glazed up bores, or perhaps an oil gallery was leaking into the combustion chamber? The head gasket was weeping a bit.
* 175psi on all cylinders, tested hot, adding a little oil does not cause the compression figures to jump.
* The head and psiton tops were not coked up, so no reason to suspect gummed up oil rings.
* No booster, so no brake fluid entering.
* No blow-by.
* It consumes some oil, but not excessive (maybe 1-2L over 3,000 miles) and it does have a couple of minor leaks.
* No blocked breathers.
Is there a "home brew" glaze busting technique I can try without diassembling the bottom end? Someone suggested a very small pinch of AJAX chucked in the intake at idle will clear bore glazing, but I don't want to perform an "instant rebore".
