changed the Waterpump and it was stuffed (pic's) https://www.ausmini.com/forums/viewtopic.php?f=2&t=12930 |
Author: | Gadgets mini [ Mon Nov 07, 2005 5:20 pm ] |
Post subject: | changed the Waterpump and it was stuffed (pic's) |
Going to change the waterpump and timing chain tomorrow ![]() besides the bypass hose if there is a easier way to do it I would be most gratefull Cheers in advance Gadget |
Author: | Mick [ Mon Nov 07, 2005 5:38 pm ] |
Bandaids..... keep 'em close. ![]() Other than that, a quarter drive socket set will save you an hour. |
Author: | aaron [ Mon Nov 07, 2005 5:59 pm ] |
i reckon you should take the radiator out first...... ![]() ![]() Sorry but had to be said. ![]() make sure you have a new set of gaskets and some good quality gasket goo. replace the seal in the timing cover as well. you might well need to lock the motor to undo the wo nuts for the timing chain. if so, try it in gear but i think you'll find the bugger will roll with you... you might be lucky. Have someone hold the car still while you undo it. When you put the bolts back in make sure to use loctite and torque them up correctly. Cheers Aaron |
Author: | Gadgets mini [ Tue Nov 08, 2005 4:10 pm ] |
Post subject: | stuffed Waterpump fixed Yay |
![]() ![]() ![]() ![]() No wonder it was gettimng a little hot there was nothing to move the water around Job went ok only needed 2 Band Aids ![]() hardest part was attaching the radiator back to the shroud specially on the firewall side ![]() |
Author: | Rodney [ Tue Nov 08, 2005 4:36 pm ] |
Whoa............that is one stuffed water pump. You'll notice a considerable difference to the old temp needle now ![]() Hooroo |
Author: | simon k [ Tue Nov 08, 2005 10:28 pm ] |
Post subject: | Re: stuffed Waterpump fixed Yay |
Gadgets mini wrote: ![]() you could make a really swish milkshake maker out of that ..... ![]() |
Author: | drmini in aust [ Wed Nov 09, 2005 5:59 am ] |
Those bent tin impeller pumps are crap... the cast iron (or even plastic) impeller ones are way better. ![]() |
Author: | CPOCSM [ Wed Nov 09, 2005 8:57 am ] |
Hmmmm - they look like the Powermax waterpump. I have one on at the moment and have done for 4 years now. Pulled it about 6 months ago to change the head gasket and all was intact and absolutely no corrosion. However the seal is now weeping and a slight dribble of coolant is occasionally drippong from the hole under the pulley nose. Time to replace... Hooroo Rob Forsyth Miniot!! |
Author: | Gadgets mini [ Wed Nov 09, 2005 10:08 am ] |
CPOCSM wrote: Hmmmm - they look like the Powermax waterpump. I have one on at the moment and have done for 4 years now. Pulled it about 6 months ago to change the head gasket and all was intact and absolutely no corrosion. However the seal is now weeping and a slight dribble of coolant is occasionally drippong from the hole under the pulley nose. Time to replace...
Hooroo Rob Forsyth Miniot!! Rob a high flow from Karcraft delivered Next day is approx$62 ![]() REPCO quoted me $65 for a standard flow and approx 2 days delivery ![]() Cheers Gadget |
Author: | CPOCSM [ Wed Nov 09, 2005 10:28 am ] |
Got the Powermax(3708 model) for $5.00 and came with a free oil filter(go figure). Winner all round. Might give Karcraft a call - Hi flow might be the way to go me thinks... Hooroo rob Forsyth Miniot! |
