It is currently Fri Aug 08, 2025 4:51 am
PostPosted: Mon Nov 07, 2005 7:32 pm
Does anyone know were I can get some 1275cc crankshaft thrust washer set in 30 thou .It's is for my A+ block with EN40B crank.It's the last part that is needed to finish of the block and looks like the hardest part to find so far.
Olly
PostPosted: Mon Nov 07, 2005 8:16 pm
You can "Tin" the back face of them & then lay solder on to as thick as you need it, & then face them back on a stone nice flat & even (or even have them machined back if you`re that picky)
done it many many many & even Many more times than i can remember
altho,,,some practice at "Tinning" & soldering would be essential
& also, if you leave the lower thrusts with more clearance than the top, it is definately a bonus in helping with crank whip/flex so as not to push on the main cap
PostPosted: Mon Nov 07, 2005 8:27 pm
Silver soldering them is better. I've seen soft solder drip off hot engine parts... not pretty!
+ .030" are no longer made.... only std or +.003" now.:cry:
Luckily when I put my S cranks into 1100S or 1300 auto blocks, I just need to surface grind the washers down by .015" each, that's easy! :wink:
PostPosted: Wed Nov 09, 2005 7:21 am
Thanks for the replys I give the silver solder a try.
PostPosted: Wed Nov 09, 2005 6:53 pm
Best way is silver solder a strip of shim steel to it. Then, put it bronze face down on the magnetic chuck, and surface grind the steel shim to thickness.
