were do you get Crankshaft thrusts 30 thou ?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=12934
Author:  mini bug [ Mon Nov 07, 2005 7:32 pm ]
Post subject:  were do you get Crankshaft thrusts 30 thou ?
Does anyone know were I can get some 1275cc crankshaft thrust washer set in 30 thou .It's is for my A+ block with EN40B crank.It's the last part that is needed to finish of the block and looks like the hardest part to find so far.
Olly
Author:  TheMiniMan [ Mon Nov 07, 2005 8:16 pm ]
You can "Tin" the back face of them & then lay solder on to as thick as you need it, & then face them back on a stone nice flat & even (or even have them machined back if you`re that picky)
done it many many many & even Many more times than i can remember
altho,,,some practice at "Tinning" & soldering would be essential
& also, if you leave the lower thrusts with more clearance than the top, it is definately a bonus in helping with crank whip/flex so as not to push on the main cap
Author:  drmini in aust [ Mon Nov 07, 2005 8:27 pm ]
Silver soldering them is better. I've seen soft solder drip off hot engine parts... not pretty!
+ .030" are no longer made.... only std or +.003" now.:cry:
Luckily when I put my S cranks into 1100S or 1300 auto blocks, I just need to surface grind the washers down by .015" each, that's easy! :wink:
Author:  mini bug [ Wed Nov 09, 2005 7:21 am ]
Thanks for the replys I give the silver solder a try.
Author:  drmini in aust [ Wed Nov 09, 2005 6:53 pm ]
Best way is silver solder a strip of shim steel to it. Then, put it bronze face down on the magnetic chuck, and surface grind the steel shim to thickness.
