It is currently Sat Jun 28, 2025 6:53 pm
PostPosted: Tue Nov 15, 2005 10:09 pm
Just wondering if you can buy new rubbers for the engine steady bar( clutch side one)
from any auto place or does it have to be a mini supplier.
thanks
PostPosted: Tue Nov 15, 2005 10:13 pm
I know my Mini supplier has 'em, in fact he has a whole box of them. (Brickworx)
I know Nolathane used to make them, i dunno if they still do or if they're good/bad. I have stuck with the rubber ones.
i got them from my local mini buissness for $ 1.50 each :wink:
PostPosted: Tue Nov 15, 2005 10:16 pm
yer steve said stick with the rubber ones
because the others fall apart after a bit of thrashing :?
PostPosted: Wed Nov 16, 2005 4:37 am
Karcraft - 85c each :wink:
Aaron
PostPosted: Wed Nov 16, 2005 5:40 am
Yep I agree the rubber ones are better- my Nolathane ones fell apart quick smart. :x
PostPosted: Wed Nov 16, 2005 7:48 am
cheers fellas, will stick with the rubber ones.
thanks
PostPosted: Wed Nov 16, 2005 9:51 am
failing that, you could always use.... :roll: .... alfoil... ;)
PostPosted: Wed Nov 16, 2005 1:51 pm
i need some new engine steady rubbers too.
PostPosted: Wed Nov 16, 2005 6:12 pm
Thanks, you just reminded me of yet another job to do :roll: :lol:
PostPosted: Wed Nov 16, 2005 6:27 pm
i'm currently using the Nolathane ones, they seem to be ok so far :shock:
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Wed Nov 16, 2005 6:44 pm
Keep an eye on them. The centre hole in them is too big.. some people wrap tape around the steel bush to make it a bit tighter. :wink:
PostPosted: Wed Nov 16, 2005 7:35 pm
I've always used one of each, don't know why really, but I guess the rubber one takes the bigger bumps out, and the nolathane just does whatever the hell it pleases. Seems to have lasted 8 years now.
