Starting probs
https://www.ausmini.com/forums/viewtopic.php?f=2&t=12949
Author:  sean [ Tue Nov 08, 2005 9:44 am ]
Post subject:  Starting probs
My clubman has not been started for a few weeks and now will not
i am getting fuel to the carby, the battery is full of charge. it turns over but will not fire I have checked the spark and it seems ok.
Any ideas ?
Author:  slide [ Tue Nov 08, 2005 9:56 am ]
Make sure you're getting a full 12 volts at the coil. Check the plug leads. How old is the fuel in the tank - unleaded starts to go off after about six weeks.
Author:  gafmo [ Wed Nov 09, 2005 6:36 am ]
also check your points and all wire connection..thery could need cleanning up :wink:
Author:  sean [ Wed Nov 09, 2005 9:38 am ]
Thanks
Will try all of the above, the fuel is super with the additive - will I need to change it?
Author:  sean [ Mon Nov 14, 2005 9:58 am ]
got it started after i had charged up the battery. lots of grey smoke from exhaust though-any ideas what this might be?
