As i am going to be getting the van out for a run on sunday i thought i should check up the brakes as i noticed tem to be a little spongy last time he was out.
So..... two months ago i replaced the rear drivers side wheel cylinder as it had been leaking. today....i replaced the other one
I should have known when one was gone that the other won't be far away. oh well. half an hour later it was swapped over, much easier than the last one, took close to 2 hours as everything was seized. thi one was a breeze. of course now i smell like brake fluid
trick for newby's and brake bleeding.
go to clark rubber or the like and by 4odd meters of plastic hose, big enough to fit over a bleed nipple. attach one end to the nipple and pop the other end into the matser cylinder. crack the nipple and pump the pedal until it runs with no bubbles. do it up, move on to the next one. easy! keep the hose for the next time you need to do it. a good idea is to get something to block up each end of the tube so the fluid left in there doesn't go all over you shed floor.
Aaron
