It is currently Mon Aug 18, 2025 2:10 pm
 Post subject: Door Hinge Bolts
PostPosted: Fri Nov 11, 2005 10:10 pm
I have a mixed bag of bolts on my door hinges. Different lengths, some are even just threaded studs with a nut. A couple have those nylock nuts on them too.
What should I have?
PostPosted: Fri Nov 11, 2005 10:15 pm
Originally, they were all studs and standard nuts, with washers.
The top ones only have tapered spacers to match the curvature of the door & A-panel.
I like studs. Bolts will work, but be careful- it's real easy to strip the threads in the hinge.
PostPosted: Fri Nov 11, 2005 10:20 pm
Thanks,
Might see if the the fastner shop can fix me up with some more studs then.
PostPosted: Fri Nov 11, 2005 10:26 pm
Bromley wrote:
Thanks,
They are 1/4" UNF thread. Easiest way is get some short 1/4" UNF setscrews from Supercrap or wherever, and just cut the heads off & deburr.. :wink:
