Door Hinge Bolts https://www.ausmini.com/forums/viewtopic.php?f=2&t=13066 |
Author: | Bromley [ Fri Nov 11, 2005 10:10 pm ] |
Post subject: | Door Hinge Bolts |
I have a mixed bag of bolts on my door hinges. Different lengths, some are even just threaded studs with a nut. A couple have those nylock nuts on them too. What should I have? |
Author: | drmini in aust [ Fri Nov 11, 2005 10:15 pm ] |
Originally, they were all studs and standard nuts, with washers. The top ones only have tapered spacers to match the curvature of the door & A-panel. I like studs. Bolts will work, but be careful- it's real easy to strip the threads in the hinge. |
Author: | Bromley [ Fri Nov 11, 2005 10:20 pm ] |
Thanks, Might see if the the fastner shop can fix me up with some more studs then. |
Author: | drmini in aust [ Fri Nov 11, 2005 10:26 pm ] |
Bromley wrote: Thanks,
Might see if the the fastner shop can fix me up with some more studs then. They are 1/4" UNF thread. Easiest way is get some short 1/4" UNF setscrews from Supercrap or wherever, and just cut the heads off & deburr.. ![]() |
