It is currently Sat Jul 19, 2025 1:41 am
 Post subject: SU high performance gaps
PostPosted: Fri Nov 11, 2005 10:23 pm
SU carbie spacers.
my 1 1/4 carbie has a half cm spacer between the carbie and manifold, without this, the manifold bolts hit the carbie body and you cant tighten it up (there is a half cm gap between).
i have a 1 1/5 carbie, there is about say 4 cm of thread on the manifold bolts, and these are hitting against the carby body, there is about a 3/4 cm gap between the carbie and manifold at this point (I dont have a spacer)
Do i need a spacer??
why are the manifold bolts so long??
Could i instead just saw 2cm from the thread and bolt it up with no spacers, or does the spacer provide some other purpose??
PostPosted: Fri Nov 11, 2005 10:29 pm
The spacer adds some volume to the manifold (and clearance behind the throttle plate) and this improves airflow.
PostPosted: Fri Nov 11, 2005 10:41 pm
Thankyou for your prompt reply Dr :)
PostPosted: Sun Nov 13, 2005 8:48 pm
What is the width of 1 1/5 SU spacers ?
I might need to get one laser cut.
I would say 10mm or more?? (ii havnt got one to look at)
Or does anyone have one i can have? :D
PostPosted: Sun Nov 13, 2005 9:14 pm
I would guess the 1-1/2" one is 10 or 12mm thick.
Hey, any Mini joint would have these S/H, they are alloy... :wink:
PostPosted: Mon Nov 14, 2005 9:38 pm
but any mini joint charges me a fortune!!
Ok this plate wasnt too bad, the gaskets wernt exactly cheap though.
So i have purchased it, does anyone have any engine bay pics of their own 1 1/2 carb on manifolds so i can ahve a look.
My air filter is mounting facing the opposite direction to the front of the car (the spout that the 1 1/4 filter mounts on is not on this 1 1/5, is this normal)
I would thinkmounting it here would be very bad for air flow +its in the way of my speedo cable!
It also appears as if this carb is a mirrored one?
anyway, any pics of 1 1/5 in engine bay if you could thanks!
