It is currently Sat Jul 19, 2025 4:23 pm
 Post subject: Starting probs
PostPosted: Tue Nov 08, 2005 9:44 am
My clubman has not been started for a few weeks and now will not
i am getting fuel to the carby, the battery is full of charge. it turns over but will not fire I have checked the spark and it seems ok.
Any ideas ?
1977 Clubman
PostPosted: Tue Nov 08, 2005 9:56 am
Make sure you're getting a full 12 volts at the coil. Check the plug leads. How old is the fuel in the tank - unleaded starts to go off after about six weeks.
Slide
1965 Mini Van (1360)
1970 Mk2 Cooper S (1310)
1978 Rover SD1 V8 (4.6)
PostPosted: Wed Nov 09, 2005 6:36 am
also check your points and all wire connection..thery could need cleanning up :wink:
PostPosted: Wed Nov 09, 2005 9:38 am
Thanks
Will try all of the above, the fuel is super with the additive - will I need to change it?
1977 Clubman
PostPosted: Mon Nov 14, 2005 9:58 am
got it started after i had charged up the battery. lots of grey smoke from exhaust though-any ideas what this might be?
1977 Clubman
Users browsing this forum: drmini in aust and 76 guests
