holy crap...just get JK https://www.ausmini.com/forums/viewtopic.php?f=2&t=13113 |
Page 1 of 2 |
Author: | inazuma_x [ Sun Nov 13, 2005 7:09 pm ] |
Post subject: | holy crap...just get JK |
http://cgi.ebay.com.au/MINI-4-SPEED-STR ... dZViewItem no way can that be worth $4000... |
Author: | benjamin [ Sun Nov 13, 2005 7:11 pm ] |
well i think the straight cut drop gears are worth $900 alone then theres lots of other goodies kad quikshift $200 bla bla bla i dunno |
Author: | inazuma_x [ Sun Nov 13, 2005 7:15 pm ] |
benjamin wrote: well i think the straight cut drop gears are worth $900 alone
each? or for a full set? |
Author: | TK [ Sun Nov 13, 2005 7:19 pm ] |
good value |
Author: | feralsprint [ Sun Nov 13, 2005 8:57 pm ] |
well I just had a look at minispares and the straight cut gear kit is 750 pounds and the drop gears about 200 pounds, so there is $2500, add the diff and the quick shift and assembly and a few other bits like bearings and syncros and its probably close to the mark at $4500 |
Author: | TheMiniMan [ Sun Nov 13, 2005 9:35 pm ] |
wake up & smell the roses Andrew,,, good bits cost good money, simple as that. remember that when you`re ready to fork out for all the "good gear" you will be needing when time comes hee hee,,,how`d you like a super dooper Close ratio 6 speed dog box with slippery quaife diff & S/C drops??? want to even have a guess what it costs?????????????????????????? |
Author: | Stuwey [ Sun Nov 13, 2005 9:42 pm ] |
TheMiniMan wrote: hee hee,,,how`d you like a super dooper Close ratio 6 speed dog box with slippery quaife diff & S/C drops??? want to even have a guess what it costs?????????????????????????? Should i sit down first? I'll bet 8k. ![]() |
Author: | drmini in aust [ Mon Nov 14, 2005 6:07 am ] |
Stuwey_LS wrote: TheMiniMan wrote: hee hee,,,how`d you like a super dooper Close ratio 6 speed dog box with slippery quaife diff & S/C drops??? want to even have a guess what it costs?????????????????????????? Should i sit down first? I'll bet 8k. ![]() And if you bust gears etc in that KG box Matt, who's got any spares.... ![]() They went bust didn't they.....! |
Author: | inazuma_x [ Mon Nov 14, 2005 7:55 am ] |
TheMiniMan wrote: wake up & smell the roses Andrew,,,
good bits cost good money, simple as that. remember that when you`re ready to fork out for all the "good gear" you will be needing when time comes hee hee,,,how`d you like a super dooper Close ratio 6 speed dog box with slippery quaife diff & S/C drops??? want to even have a guess what it costs?????????????????????????? the thing was that this gb is $4000ish...you could get a similarly spec'd jack knight box for that...sure you would just get the gears (ie. no gear housing or quickshifter...) but wouldnt a jack knight box brand new be better than a 2nd hand reconditioned box like this? |
Author: | feralsprint [ Mon Nov 14, 2005 8:29 am ] |
From what I have seen and heard over the last few years the JK gears are not as good as once was, the case hardening is failing |
Author: | inazuma_x [ Mon Nov 14, 2005 8:36 am ] |
hmmm...thats not good news...i thought they just landed some deal with a few F1 teams to make boxes for them... |
Author: | VeG [ Mon Nov 14, 2005 9:02 am ] |
Quote: Would suit Race/ Rally car
hence $4500 ![]() i want it! |
Author: | drmini in aust [ Mon Nov 14, 2005 9:07 am ] |
Right now, the MiniSpares 4 synchro SCCR gears are probably best for racing- unless you can afford the new sequential dog box KC is raving about. |
Author: | feralsprint [ Mon Nov 14, 2005 9:11 am ] |
Mate, Formula one gearboxes are built to last just the length of the race and then they are thrown away, they build them as light as possible and usually dont have a full box of gears left at the end of the race Straight cut boxes are not really good for street use as the nature of the box is to be strong and not consume as much power as a helical cut box but the mating surfaces of the gear is actually less than a helical box so there for the gears are not as durable for milage Jon |
Author: | marcsvenson [ Mon Nov 14, 2005 9:35 am ] |
perhaps it is overkill for your needs anyways the standard mini box isnt that weak as long as your not driving like a maniac 24/7 IF you are building a full blown race car go for it if not i wouldnt spend it imho |
