New ignition coil https://www.ausmini.com/forums/viewtopic.php?f=2&t=1313 |
Author: | IwannaMini [ Tue Jul 27, 2004 10:06 pm ] |
Post subject: | New ignition coil |
Is this a $29.95 part from the usual auto places or is the ignition coil something that needs to be 'ordered' in special. Is there any particular type that I should ask for. ![]() |
Author: | gafmo [ Tue Jul 27, 2004 10:38 pm ] |
Do you have a resitor connected to your Coil ususaly a white block going to your fuse box. I made the mistake of purchasing a GT40 coil that needed a resistor when all i neede to do was to get a GT40 T, wich does not need a resistor. Sue spent a month without Morris becouse I purchased the wrong Coil. Additional $140 to find the problem ![]() |
Author: | drmini in aust [ Tue Jul 27, 2004 10:38 pm ] |
If it's an Oz made Mini any 3 ohm 12V coil will do. Bosch GT40 is good, don't buy the GT40-R unless you have a ballast resistor fitted (99% of Minis here don't) |
Author: | gafmo [ Tue Jul 27, 2004 10:40 pm ] |
Sorry I had it around the wrong way. Yet the Dr help me ![]() |
