It is currently Wed Aug 06, 2025 3:30 am
 Post subject: Moke Trailing arms
PostPosted: Tue May 23, 2006 10:09 pm
So are moke rear trailing arms the same size and shite as normal mini ones? I hear that they may be different??
Chris
PostPosted: Tue May 23, 2006 10:12 pm
I think they are longer by an inch or three ......
J
PostPosted: Tue May 23, 2006 10:47 pm
Chris
They are longer and if you need two I have a moke in the back yard that is shortly going to god.
Steve
PostPosted: Tue May 23, 2006 10:48 pm
Big wheel ones are longer, but I think the 10" wheel Mokes were same arms as Mini.
The big wheel arms have needle bearings both ends of shaft, not that ****ing bush.... :x 8)
PostPosted: Wed May 24, 2006 8:32 am
I've posted this before but here goes again:
Shock mount is in same place as 10" but stub axle is a couple of inches further from pivot.
