Help Problem, cant reverse
https://www.ausmini.com/forums/viewtopic.php?f=2&t=13283
Author:  catzzmandu [ Sat Nov 19, 2005 7:34 pm ]
Post subject:  Help Problem, cant reverse
Eeek. I cant get my mini into reverse. We pulled he gear stick out to put in a quick shift & am trying to put the old gear stick back in and all the gears work except the pull to reverse. Can someone help. Think we missed something.
Author:  mad-mk1 [ Sat Nov 19, 2005 7:42 pm ]
i think u misssed the reverse!!! :P :P
thats ok just drive it hard and fast forward and trynot to get into any situations when u need reverse.
meet the old handbrake drifting :D
actually i have no idea sorry!!!
Author:  meeni [ Sat Nov 19, 2005 7:53 pm ]
u mean to say u put a quick shifter on with the origional gear shifter?? i think thats ur problem, u need a special stick for them, other then that it might be that uve missed the hole in the bottom of the selector housing
Author:  Chowzilla [ Sat Nov 19, 2005 8:43 pm ]
Obviously the quick shifter was taken out, and the old one was replaced since the quick shifter did not fit. Once the original was replaced the gearbox would not engage into reverse after lifting and pulling back the stick. Instead it slid back into 4th gear, can anyone actually help with this problem? And yes the shifter was placed into the hole in the bottom of the selector housing otherwise I would not have been able to replace the gearlever box cover, or have been able to shift into gears 1 through 4.
Author:  ausminis4u [ Sun Nov 20, 2005 7:48 am ]
what sort of gear box is it ? also dont listen to any technical info from meeni he has no idea :lol: if you put the type of box or year model we may be able to help or give a more accurate diagnosis.
Author:  catzzmandu [ Sun Nov 20, 2005 11:38 am ]
It's a clubman gearbox I think, engine is a clubman 1ltr so I guess the gearbox is clubman but the morris mini is a 65 roundie.
Author:  catzzmandu [ Sun Nov 20, 2005 11:39 am ]
It's a pull to reverse gear, pretty sure it's a rod one.
Author:  ausminis4u [ Sun Nov 20, 2005 3:00 pm ]
yeah, rod change. have you tried to fit the original shifter and get reverse again? have you fitted the spring and plastic cup from ya old shifter?
Author:  catzzmandu [ Sun Nov 20, 2005 3:09 pm ]
The original shifter was replaced after the quickshifter was taken out and everything was put back the way it was, except it no longer shifts into reverse. When the shifter is pulled up it either doesn't shift to reverse or slides back into 4th, I have no idea whats going on?
Author:  Chowzilla [ Sun Nov 20, 2005 6:11 pm ]
Yeah the bastard shifter is fixed. I hate min...i only joking... relax peoples
