thanks to all the SE QLD guys https://www.ausmini.com/forums/viewtopic.php?f=2&t=13290 |
Page 1 of 2 |
Author: | inazuma_x [ Sun Nov 20, 2005 12:46 am ] |
Post subject: | thanks to all the SE QLD guys |
thanks for comin over and helping me get the front and rear subframes out...went pretty smoothly i thought ![]() anyway...couldnt have done it without you guys...darrin has some pics that he took of the exercise...post em here if ya will dazza ![]() |
Author: | gafmo [ Sun Nov 20, 2005 7:19 am ] |
Good move having a busy bee on, A few mate around, Beer, Bqq and talk about mini's ![]() |
Author: | clubby123 [ Sun Nov 20, 2005 10:40 am ] |
should organise another one i'll come for sure just need weeks notice and then you guys can fix my mini ![]() |
Author: | nermil [ Sun Nov 20, 2005 1:46 pm ] |
Author: | inazuma_x [ Mon Nov 21, 2005 9:12 am ] |
nice pics ![]() ![]() |
Author: | Metalfab_101 [ Mon Nov 21, 2005 9:48 am ] |
inazuma_x wrote: nice pics
![]() ![]() Rumour has it that shell is schmick. Cut the front off it at your own risk, as I can bet there'll be a line up to take to your nuts with a grinder ![]() |
Author: | Zizzle [ Mon Nov 21, 2005 9:54 am ] |
So is that danidad the bronzed Gold Coaster, NAV with gafmo's work boots on, gazza the perfectionist, inazuma_x the romper stomper? |
Author: | inazuma_x [ Mon Nov 21, 2005 9:59 am ] |
i've heard the same too...but if i am going an engine conversion i'll want the flipfront...in my opinion its better as it gives more room under the "hood"... |
Author: | inazuma_x [ Mon Nov 21, 2005 10:00 am ] |
Zizzle wrote: So is that danidad the bronzed Gold Coaster, NAV with gafmo's work boots on, gazza the perfectionist, inazuma_x the romper stomper?
YEP ![]() |
Author: | Mike_Byron [ Mon Nov 21, 2005 10:27 am ] |
How was the broth ?????? Sorry - it looks as though you had a good crew. I dont think I have ever seen brand new engines stands before. |
Author: | inazuma_x [ Mon Nov 21, 2005 10:30 am ] |
was a good day ![]() i wouldnt have bought new jack stands if i already had a set lying around ![]() ![]() |
Author: | Mike_Byron [ Mon Nov 21, 2005 10:40 am ] |
We all have to start somewhere. I had about 10 years away from working on cars while i learnt to be a farmer and when I started on minis again it was amazing how many tools and bits had just disappeared. Just been eaten by mice i think. Talking about mice eating things. A mate has just started harvesting a couple of acres of wheat. He went to start his Acco truck (with a bin on it for the wheat grain) and found it wouldn't start, mice had eaten the wiring and then when he had the wiring fixed, the air brakes wouldn't release and the mice had also eaten the air brake hoses and it wouldn't pump up enough pressure to release the brakes. |
Author: | inazuma_x [ Mon Nov 21, 2005 10:44 am ] |
i had mice as pets when i was a kid...something you learn from caring for mice is: if you put anything thats plastic in their cage that has an edge on it it will be chewed and knawed into nothingness within days...i believe they do it to keep the length of their teeth under control...as they continue to grow forever...and if they dont chew they end up with such long teeth that they can no longer eat...hence the expression "he's getting a bit long in the tooth" |
Author: | J_A_M [ Mon Nov 21, 2005 10:55 am ] |
well done guys!! many handas make light work ey?!? ![]() |
Author: | inazuma_x [ Mon Nov 21, 2005 11:00 am ] |
light work except when you forget to remove the battery lines and have to run upstairs to get some tin snips while everyone is holding the front end up in the air ![]() |
