It is currently Wed Aug 06, 2025 9:27 am
 Post subject: Grease Gun Hydro Pump
PostPosted: Mon Nov 21, 2005 9:32 am
The drivers side on the clubby is well down which I thought may need replacing.
But after depressing the valve at the rear and getting covered in fluid which was
obviously under great pressure I'm hoping it just needs pumping up.
There are no signs of leakage.
I'm about to go and buy the bits to make a 'Grease Gun hydro pump', as per instructions found on an Ausmini thread, has anyone else made and used one of these successfully?
PostPosted: Mon Nov 21, 2005 3:10 pm
I made one a while back and it works fine. I had to glue up some of the adapter joins to stop it leaking, but now it works fine.
Paying $50 once for the pump beats $40 a pump up at the mini shop!
PostPosted: Mon Nov 21, 2005 3:19 pm
I was just quoted $50 for the tractor tire water filling attachment.
Is this what you used?
If so where did you purchase it?
If not, what fittings did you use and where did you find them?
PostPosted: Mon Nov 21, 2005 3:21 pm
You must also use some sort of bleed type system on your pump as air in the system does bad things.
PostPosted: Mon Nov 21, 2005 3:43 pm
i got it for $20 from rimtec in Belmont, Perth
PostPosted: Mon Nov 21, 2005 3:47 pm
I just located one for $30 and ordered it.
Thanks for the help.
PostPosted: Mon Nov 21, 2005 5:04 pm
If you can get someone that can silver-solder or braze just get a metal valve cap (not a plastic one) drill a hole in the end and solder/braze it to a pipe fitting. :wink:
I made my hydro pump from an old master cylinder and some hose. Total cost $0.
PostPosted: Mon Nov 21, 2005 6:44 pm
i used the tractor fitting way and worked well... :lol: :lol: (pitty the car had to get wrecked damn rust)
My rides-74 fj40
74 clubman hopefully rego'd soon....
and 76 clubbie van!! - Ratschite after what i found what it was covered in when i found her...
http://photobucket.com/albums/b44/minimechanic/?sc=1
