It is currently Sun Aug 10, 2025 1:10 am
 Post subject: Leaky Box
PostPosted: Fri Oct 14, 2005 11:48 am
well i need to fix the leak on a rod change box where th selector goes in
but the problem is I need to order the stuff (seals or kit) but I have loaned the karcraft catalogue out and cant get it back for a while ( I did order them last time but I must of been way off cause they arent the right seals :oops:
So please tell me exactly what to order please :lol:
also are these the go? http://www.minimania.com/web/AddedFrom/Suggest_Cart/Item/MSSK050/InvDetail.cfm
thanks in advance
harley
67' Matic
73' S
PostPosted: Fri Oct 14, 2005 12:43 pm
Oil seal - gearbox - selector shaft - mini (rod change) AHU1672
I also fit two of these
Pete
PostPosted: Fri Oct 14, 2005 3:57 pm
www.karcraft.com.au
They have a full online catalogue now with a comprehensive search function.
PostPosted: Fri Oct 14, 2005 6:35 pm
thanks guys :wink:
but with that karcraft online catalogue I find it a POS to use :evil:
even with your post it is hard to get it to work unless you put in part number :?
I wish they would make it online ordering so I could do it in my owntime(night time)
also can you get the kit I mentiond earlier in oz because I want somthing better as I have seen the seals leak after new ones have been installed
67' Matic
73' S
PostPosted: Fri Oct 14, 2005 6:40 pm
ok I just went back to the karcraft website and got it working I was making my searches to complicated :oops:
67' Matic
73' S
PostPosted: Fri Oct 14, 2005 6:50 pm
Coops just remember to put at least two of those seals in there.
Mine had 3 :wink:
PostPosted: Mon Nov 21, 2005 3:36 pm
In regards to the selector rod what do you use to get the pin out so the rod can be removed?
Im using a punch but the f$^^k in pin will not move.
Any ideas
PostPosted: Mon Nov 21, 2005 4:25 pm
Any ideas
First put it into reverse.
You only need the front pin out.
Use a 3/16" pin punch (NOT a nail or whatever) and a BFH. :wink:
PostPosted: Mon Nov 21, 2005 4:33 pm
Thanks Doc i will try putting it in reverse first
By the way the rod looks like its been cut and rewelded looks like the prevoius owner or mechanic had tried the punching the pin before and was unsucessful :lol:
Now finding the room between the stands and box to swing that BFH is gonna be fun :D
PostPosted: Mon Nov 21, 2005 4:57 pm
That's why U put it in reverse, you can get a clean hit then.
PostPosted: Mon Nov 21, 2005 5:09 pm
my gearbox had 4 of these :)
PostPosted: Mon Nov 21, 2005 6:37 pm
I use the Rod Change repair kit - it has the seal, alloy rod centralising insert, o ring for afore-mentioned insert and a consatina rubber cover that goes over the whole shebang. Costs $14 bucks and havent had a leak in 50,000km...
I will hunt around for a number for you...
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
