It is currently Wed Aug 13, 2025 10:31 am
 Post subject: Door handle sloppiness
PostPosted: Sun Nov 20, 2005 9:46 pm
Hi all
I'm a not so long time reader first time poster....
Does anyone know where you can get a spring to stop the door handle "slop" on a morris? On the shaft of the handle once I removed it were 4 washers secured by a split pin guessing instead of the washers there's a spring that goes there or am I wrong??
pic for you all:
PostPosted: Sun Nov 20, 2005 10:24 pm
Yes there is a spring I know mini spares Padstow have them as I bought mine there.
Thats Sydney anyhow
steve
 Post subject: handle
PostPosted: Sun Nov 20, 2005 11:07 pm
When you do get the spring and install the handle, make sure you get the positioning of the spring correct, follow a workshop manual if you have one.
Sometimes when you position the spring and the handle it looks right but then the outer handle is sloppy and wont stay "horizontal" when the door is closed. Get it right and everything works fine :D
Mini door handles and locks are a pain in the a** compared to most cars :P
PostPosted: Mon Nov 21, 2005 8:48 am
Cheers will give em a call
:D
Users browsing this forum: No registered users and 284 guests
