It is currently Mon Jul 21, 2025 3:17 am
 Post subject: Cooper disc brakes
PostPosted: Tue Nov 22, 2005 7:48 am
I have a few sets of Cooper 7" disc brakes and i was wondering if the 7.5" Cooper S rotors will fit on the hubs or are they completly different. I suppose the calipers would be different too. The 7" rotors I have a quite worn i think and I thought I could upgrade to 7.5 rotors. Any advice would be appreciated.
Steve.
PostPosted: Tue Nov 22, 2005 8:25 am
High heel ninja
Yes S discs will fit, all mini disc brake hubs are the same, you can easily update to S brakes by changing over the disc,caliper & drive flange.
Doogie
PostPosted: Tue Nov 22, 2005 8:39 am
Thanks Doogie, does this mean i could put 8.4" rotors on, if i am going to upgrade i may as well go all the way.
Steve.
PostPosted: Tue Nov 22, 2005 8:44 am
High heel ninja
Sure can, i might even have a set of caliper & discs lying around here, if you need some.
Doogie
PostPosted: Tue Nov 22, 2005 10:03 am
I know someone here in Wagga looking for a pair of Cooper rotors.
PostPosted: Tue Nov 22, 2005 11:13 am
Bromley, I think one set of rotors is no good, I will have a close look. I may still use the other set if they are ok. I will get back to you about that. Does anyone know how thin is too thin for the Cooper rotors.
Steve.
PostPosted: Tue Nov 22, 2005 4:09 pm
Just a quick barrier perhaps,
The CV's for the cooper discs are the same as drum brakes, the CV's that are needed for S brakes or 8.4's i think are different.
Hope this helps. Check it out though
Brad
http://www.cardomain.com/id/skimini82
PostPosted: Tue Nov 22, 2005 4:53 pm
Steve,
When I got my rotors machined the brake people had a book with all the widths. Maybe try calling a brake place if you get no luck on here. I am also digging up a photo of the rotors taken out of my mates car. They were wafer thin, I snapped one in half with my hands like a biscuit!
PostPosted: Tue Nov 22, 2005 6:03 pm
High heel ninja
I think around 8.5mm is the minimum for a mini brake dics, but don't qoute me on it
Doogie
PostPosted: Tue Nov 22, 2005 6:46 pm
Cooper 997 & 998 rotors are only 1/4" (6.35mm) thick when new. I believe minimum limit is 5mm.
Sure it's thin but they still do work, haha. 8)
 Post subject: Brom the incredible Hulk
PostPosted: Tue Nov 22, 2005 7:59 pm
Ffffffrigthening....the power of the man :P
PostPosted: Sun Nov 27, 2005 10:18 am
are cooper drive flanges and cooper s drive flanges the same? apart from the cv diameter?
if so couldnt you use 7'' flanges with drum CVs with cooper s discs and calipers?
that makes sence to me as the drive flange on cooper discs looks the same as cooper s to me, and would make things a hell of alot cheaper
PostPosted: Sun Nov 27, 2005 11:57 am
No, unfortunately they are totally different. Cooper 997 & 998 used the drum type CV, the Cooper drive flange looks like the offspring of an S and a drum one.
ps I might have a spare s/h S one, I'll look.
