Cooper disc brakes https://www.ausmini.com/forums/viewtopic.php?f=2&t=13364 |
Author: | Flying Brick [ Tue Nov 22, 2005 7:48 am ] |
Post subject: | Cooper disc brakes |
I have a few sets of Cooper 7" disc brakes and i was wondering if the 7.5" Cooper S rotors will fit on the hubs or are they completly different. I suppose the calipers would be different too. The 7" rotors I have a quite worn i think and I thought I could upgrade to 7.5 rotors. Any advice would be appreciated. Steve. |
Author: | doogie [ Tue Nov 22, 2005 8:25 am ] |
Yes S discs will fit, all mini disc brake hubs are the same, you can easily update to S brakes by changing over the disc,caliper & drive flange. Doogie |
Author: | Flying Brick [ Tue Nov 22, 2005 8:39 am ] |
Thanks Doogie, does this mean i could put 8.4" rotors on, if i am going to upgrade i may as well go all the way. Steve. |
Author: | doogie [ Tue Nov 22, 2005 8:44 am ] |
Sure can, i might even have a set of caliper & discs lying around here, if you need some. Doogie |
Author: | Bromley [ Tue Nov 22, 2005 10:03 am ] |
I know someone here in Wagga looking for a pair of Cooper rotors. |
Author: | Flying Brick [ Tue Nov 22, 2005 11:13 am ] |
Bromley, I think one set of rotors is no good, I will have a close look. I may still use the other set if they are ok. I will get back to you about that. Does anyone know how thin is too thin for the Cooper rotors. Steve. |
Author: | skimini82 [ Tue Nov 22, 2005 4:09 pm ] |
Just a quick barrier perhaps, The CV's for the cooper discs are the same as drum brakes, the CV's that are needed for S brakes or 8.4's i think are different. Hope this helps. Check it out though Brad |
Author: | Bromley [ Tue Nov 22, 2005 4:53 pm ] |
Steve, When I got my rotors machined the brake people had a book with all the widths. Maybe try calling a brake place if you get no luck on here. I am also digging up a photo of the rotors taken out of my mates car. They were wafer thin, I snapped one in half with my hands like a biscuit! |
Author: | doogie [ Tue Nov 22, 2005 6:03 pm ] |
I think around 8.5mm is the minimum for a mini brake dics, but don't qoute me on it Doogie |
Author: | drmini in aust [ Tue Nov 22, 2005 6:46 pm ] |
Cooper 997 & 998 rotors are only 1/4" (6.35mm) thick when new. I believe minimum limit is 5mm. Sure it's thin but they still do work, haha. ![]() |
Author: | 9YaTaH [ Tue Nov 22, 2005 7:59 pm ] |
Post subject: | Brom the incredible Hulk |
Bromley wrote: They were wafer thin, I snapped one in half with my hands like a biscuit!
Ffffffrigthening....the power of the man ![]() |
Author: | benjamin [ Sun Nov 27, 2005 10:18 am ] |
are cooper drive flanges and cooper s drive flanges the same? apart from the cv diameter? if so couldnt you use 7'' flanges with drum CVs with cooper s discs and calipers? that makes sence to me as the drive flange on cooper discs looks the same as cooper s to me, and would make things a hell of alot cheaper |
Author: | drmini in aust [ Sun Nov 27, 2005 11:57 am ] |
benjamin wrote: are cooper drive flanges and cooper s drive flanges the same? apart from the cv diameter?
if so couldnt you use 7'' flanges with drum CVs with cooper s discs and calipers? that makes sence to me as the drive flange on cooper discs looks the same as cooper s to me, and would make things a hell of alot cheaper No, unfortunately they are totally different. Cooper 997 & 998 used the drum type CV, the Cooper drive flange looks like the offspring of an S and a drum one. ps I might have a spare s/h S one, I'll look. |
