Speco water temp sensor wire replacement? https://www.ausmini.com/forums/viewtopic.php?f=2&t=13448 |
Author: | h0nk [ Thu Nov 24, 2005 8:34 pm ] |
Post subject: | Speco water temp sensor wire replacement? |
Anyone know if it's possible to get a replacement for the sensor and the pipe attached to it, for a mechanical specometer water temp guage? I managed to snap the pipe.. I tried Repco but they reckon you have to replace the whole guage. Pain in the ass $50 just cause the little pipe broke. ![]() |
Author: | minimaniac [ Fri Nov 25, 2005 9:40 am ] |
Unfortunately you will need to get a new gauge as they are one unit & if the pipe is stuffed the gauge won't work. |
Author: | min13k [ Fri Nov 25, 2005 6:53 pm ] |
some instrament places can fix it but it could costya more than the gauge is worth makka |
Author: | CPOCSM [ Sat Nov 26, 2005 8:06 am ] |
Concur with Makka - the tube is filled with ether - very very flammable and is a gas at room temperature hence would be impossible to refill unless in space!. Repco occaisionally have Speco on special for $29 dollars so replace the guage - I reckon it would cost you an arm and a leg to get the tube repaired. Hooroo Rob Forsyth Miniot!! |
Author: | aaron [ Sat Nov 26, 2005 8:32 am ] |
i had a smiths temp(mechanical) guage repaired, cost me $150 to have the new sender fitted with new ether, serviced and calibrated. It's cheaper to buy a new one, unless it's hard to find. cheers aaron |
Author: | h0nk [ Sat Nov 26, 2005 2:07 pm ] |
Yep I'll probably have to buy a new one.. I was just hoping Speco sold these as replacements. |
