Shard wrote:
My temp guage is behaving weirdly it resets to zero when the car is off, but on ignition and idle it sits on max temp and then when i take off it goes beyond max and the needle sits right at the end of the viewing window. Is this just a wires around the wrong way prob? Don't want to hook it up in reverse in case the needle brakes or something without asking first.
Is the fuel guage working properly
If not it is likely to be the voltage regulator
Otherwise check all your contacts are good but it might be a stuffed guage or temperature sender.
Shard wrote:
And finally, where is my tappet cover breather and is it easily unblocked. Link say mines partially blocked. I have nfi where it is but if it's easy to get to I might just give it a go myself unblocking it,
cheers!
Shard
Down the back of the motor those little covers, one of the two presumably has a breather on it
