Clutch arm pivot pin wear https://www.ausmini.com/forums/viewtopic.php?f=2&t=13486 |
Author: | J_A_M [ Sat Nov 26, 2005 7:35 am ] |
Post subject: | Clutch arm pivot pin wear |
I am in the process of removing my clutch. I took the clutch arm pivot pin out and noticed that it is worn quite badly on one side . How does this effect the clutch operation? |
Author: | CPOCSM [ Sat Nov 26, 2005 7:50 am ] |
Every little bit adds to any problem you may have with your clutch. I too am about to replace it as I have a nice groove worn in the clevis pin. Going to chaeck out Classic Motoring to see if they have any lying about. Hooroo Rob Forsyth Miniot!! |
Author: | J_A_M [ Sat Nov 26, 2005 10:32 am ] |
I went out and picked up a new one this morning from Mini Spares in Seven Hills. $4.95. |
Author: | CPOCSM [ Sun Nov 27, 2005 11:07 am ] |
J_A_M wrote: I went out and picked up a new one this morning from Mini Spares in Seven Hills. $4.95.
BASTARD!!! I paid $5.50!! Ce La Vie!! Makes a difference with new stuff though - doesnt it... Hooroo Rob Forsyth Miniot!! |
Author: | J_A_M [ Sun Nov 27, 2005 7:22 pm ] |
HA HA ![]() Mine is all back in....pedal feels better with new pin. Probably because there is no slack now. |
Author: | chopchop [ Sun Nov 27, 2005 8:35 pm ] |
Anton, your sounding like an expert with the clutch now, might have to bribe ya with beere to see whats up with mine ![]() |
Author: | mickmini [ Sun Nov 27, 2005 8:42 pm ] |
Post subject: | Re: Clutch arm pivot pin wear |
J_A_M wrote: I am in the process of removing my clutch. I took the clutch arm pivot pin out and noticed that it is worn quite badly on one side .
How does this effect the clutch operation? Anton, i can't believe you forgot the stuff you learnt from Marcel Chicak stuff that you read here http://www.ausmini.com/forums/viewtopic.php?t=9120&postdays=0&postorder=asc&start=15 ![]() of course it makes a huge difference. hope JAM is all better now michael |
Author: | J_A_M [ Sun Nov 27, 2005 8:53 pm ] |
ahhh...I didn't forget any of that stuff......for that is why I replaced the pin ![]() Clutch feels better, sadly the idler gear is still too tight ![]() |
