It is currently Tue Jul 29, 2025 7:41 am
 Post subject: Front suspension
PostPosted: Mon Dec 05, 2005 10:09 am
I have a 1967 mini morris delux and her front drivers side suspension has collapsed... Does anyone know of a good mechanic that could help me out???
[/quote][/list]
PostPosted: Mon Dec 05, 2005 10:12 am
Location will help.
There is a lest of mini Based buinesses listed in the HOW TO section. that should help you on your way.
Aaron
PostPosted: Mon Dec 05, 2005 10:31 am
I'm guessing you have hydrolastics so it is either:
One of your displacers have blown trying to get a replacement might be tricky..
or
the system might just need a pump up (easier fix)
The hydrolastic displacers can be found above the front suspension turrets or laying horizontally in the rear subframes check around the hoses for leaks / seepage.
This is of course assuming your mini is hydrolastics. :roll:
Roads need more corners
PostPosted: Mon Dec 05, 2005 10:34 am
Yes my baby has hydrolastics no leaks she just decided to lower herself... My mechanic does not deal with the in's and out's of minis so he has given me the number for mini spares and repairs at castel hill but im abit sceptical about giving my car to people because my originally mechanic stuffed me around...
PostPosted: Mon Dec 05, 2005 10:46 am
If you are sure it has just let it's hydrolastics down phone around for a place that has a hydrolastics pump or beg borrow or steal one and pump it up again and your done the hydrolastics do go flat for whatever reason.
So your in Sydney then ?
A lot of people on here are from Sydney so they might be able to help you out.
Karcraft in silverwater sell the hydrolastic fluid.
Alternatively you could make your own hydrolastic pump there are a couple of designs floating around here do a search. :wink:
And fill inyour location field in your profile so people know where you are and can offer help :wink:
PostPosted: Mon Dec 05, 2005 10:49 am
Ivan at Mini Spares and Repairs is an absolute legend. 8)
I highly recommend him. Every time I've been there he has explained everything to me and is just an awesome bloke to deal with.
Margaret - 88 Rover
PostPosted: Wed Dec 07, 2005 7:57 pm
I went to Ivan and that guy is excellent! I have found my new mini mechanic... He fixed the suspension for me and pointed out a few other things that need to be fixed! Finally I'v found someone that knows what they are doing!!!
PostPosted: Wed Dec 07, 2005 8:16 pm
you want have any troubles with Ivan..he does good work and knows his mini's :wink: and will look after you
PostPosted: Thu Dec 08, 2005 5:27 am
Ivan has a 40 yr old history racing and ralying minis, formula junior racers and coventry climax specials. Infact he has an amazing collection including 970 and 1071 Coop Ss and several John Cooper specials.
Hes an inredibly experienced guy and a pleasure to deal with - but these days I understand that he wants to focus on his racers and projects so he's got another guy taking over the day to day in the workshop. He is supposed to be good as well though/
PostPosted: Thu Dec 08, 2005 5:48 am
Greig Malaure at Mini Classic in Hope St, Ermington is good too. Also, he now has a dyno.... 8)
