WHAT AM I DOING WRONG?!!?!?
https://www.ausmini.com/forums/viewtopic.php?f=2&t=13759
Page 1 of 2
Author:  Betty [ Tue Dec 06, 2005 10:02 am ]
Post subject:  WHAT AM I DOING WRONG?!!?!?
big strong mechanics suck.
and now i cantget that stupid oil filter out
and cant even nudge it at all
it sjut on so tightly
i have done everything !!
i have a oil filter remover thing
and the wrech that fits it... and i have even pierced the filter with a screw driver, ho[ing that it would be able to nudge the stupid thing!
BUT NO
my back is sore
and my arms hurt
and i unscrewing the the wrong way? is it clockwise or anti clockwise i have to turn it?!
so tell me what i am doing wrong
either the filter is on too tightly..
or i am just dumb!!
NOT HAPPY JAN
:evil: :evil: :evil: :evil: :evil: :evil:
Author:  cush [ Tue Dec 06, 2005 10:15 am ]
stab it with a big screw driver and turn it with that..
Author:  Betty [ Tue Dec 06, 2005 10:21 am ]
i have done that cush!
nothing works
i need to grow big manly muscles i think!!
Author:  fuzzy-hair-man [ Tue Dec 06, 2005 10:25 am ]
There is the problem that sometimes when people put on oil filters they forget to smear some oil over the rubber O ring which makes them very hard to get off. :evil:
I figure it has to come off especially now it has a hole in it :( so just keep trying.
I don't have a oil filter removal tool so I use a bit of rope tied in a loop with a open ended ring spanner inserted into the loop so it tightens up the loop as I twist the spanner. I use a screw driver or another spanner at the other end of the open ender. :wink: means if I can't get it undone I need to go find another (longer) spanner or screw driver to stick on the end.
It does tend to crush the oil filter though :roll: but who cares as long as I can get it off :wink:
Author:  poeee [ Tue Dec 06, 2005 10:38 am ]
We had a filter that wouldn't budge on my cousins Clubman when he first bought it.
We had to go to the extent of taking off the filter head and carefully attack the filter with a hacksaw. :evil:
Author:  Lillee [ Tue Dec 06, 2005 10:40 am ]
Oh well Betty, let me know if you still can't get it off, I will come over with an extension pole, a BFH and IT guy muscles :wink:
Author:  Lillee [ Tue Dec 06, 2005 10:41 am ]
I hope it doesn't get to that! :shock:
Author:  68matic [ Tue Dec 06, 2005 1:52 pm ]
i reckon filters should be done up handtight only, once things heat up things get tighter
before you warm your car, you should undo it a little whilst cold
it will be easier to get off while hot
emme try waiting for things to get cold again
or tap the screwdriver with a hammer
it comes off like all threads: anti c to undo
Author:  aaron [ Tue Dec 06, 2005 1:56 pm ]
i think the mighty Gafmo is going to show his strength and rescue the maiden in distress. :wink:
Aaron
Author:  Betty [ Tue Dec 06, 2005 2:28 pm ]
nothing has worked thus far
and it is actually cold atm.. i have been trying for two days now.. :oops:
ad i really do feel like a retard becasue i cant undo a screw :S
my final thought is to turn it clockwise.. becasue the filter is upside down...
but i might be wrong??
and yes.. mighty gafmo might be able to rescue lil Betty!
hacksaw is sounding good ! :lol:
Author:  GT1360 [ Tue Dec 06, 2005 2:30 pm ]
Aaron
what scare it of with that bald mug of his :P
Author:  awdmoke [ Tue Dec 06, 2005 3:14 pm ]
Yes, if you are looking down through the engine bay.
Sometimes they can be a real bugger - don't feel bad.
Once I did that with the screwdriver hammered right through & out the other side and put my full force behind it - ended out ripping the oil filter in half :x
Author:  h0nk [ Tue Dec 06, 2005 3:51 pm ]
I find this works well:
Make a hole in the side of oil filter (might need to be a bit bigger then a screwdriver) and stick a bunger in there.. light the fuse, stand back, and the oil filter should come off nicely by it's self. You may have to replace a few other engine parts that get damaged in the process.
Author:  Betty [ Tue Dec 06, 2005 4:02 pm ]
ha ha
ok h0nk
will try your idea! :idea:
Author:  Mike_Byron [ Tue Dec 06, 2005 4:24 pm ]
Went through this on Saturday
Ended up disconnecting the oil cooler hoses, taking off the filter and the carrier and locking the filter in a pipe vice and heaps and heaps of muscle. Resist the temptation to stick a screw driver in the bolt holes and twist from there. Doing that will only break the bolt holes off.
Then - once the filter is off - get someone to run a die up the thread as you can almost guarrantee the thread is stretched.
