Rear Brakes Thingo https://www.ausmini.com/forums/viewtopic.php?f=2&t=13899 |
Author: | monrel [ Sun Dec 11, 2005 12:51 pm ] |
Post subject: | Rear Brakes Thingo |
Hi! Im sorting out my brake lines in the rear, and I wanted to know how I can test this thing to see if it needs replacing... ![]() What is it called? Apart from cleaning it up, what else do I have to do before refitting it? |
Author: | awdmoke [ Sun Dec 11, 2005 2:19 pm ] |
Looks like a bias valve - no idea how to test if not connected to the master cyl. ![]() |
Author: | monrel [ Sun Dec 11, 2005 2:43 pm ] |
Post subject: | bias valve |
yeah, bias valve sounds about right. Thanks mate! Well, until I find out how I can suss out if I need a new one or not, I'll just blast it with some sand, and paint ![]() |
Author: | Bromley [ Sun Dec 11, 2005 5:07 pm ] |
That thing controls the amount of hydraulic pressure between the front and rear brakes. I have been told that they very rarely need replacing or repairing because I was in the same position as you are in. I just put mine back on. |
Author: | mickmini [ Sun Dec 11, 2005 5:48 pm ] |
pull it apart and clean out crud if there is any. check to make sure piston moves freely and the o rings are not perished. if they are there is a kit you can get pretty cheap to make it all good again. |
Author: | monrel [ Sun Dec 11, 2005 7:21 pm ] |
thanks for the advice guys!! |
Author: | 9YaTaH [ Sun Dec 11, 2005 7:25 pm ] |
Post subject: | words.. |
awdmoke wrote: Looks like a bias valve - no idea how to test if not connected to the master cyl.
![]() front to rear proportioning valve.. ![]() |
Author: | TheMiniMan [ Sun Dec 11, 2005 9:44 pm ] |
No,,,not a bias valve or a proportioning valve it`s called a pressure limiting valve std mini (drum brake type) ones allow more pressure to the rear that the "S" (disc) ones & therefore 2 different kits avaliable normally they don`t give trouble & also you can mnake them adjustable if you like ![]() tricky hey? ![]() easy-peasy |
Author: | 9YaTaH [ Sun Dec 11, 2005 9:47 pm ] |
Post subject: | Cruel.... |
TheMiniMan wrote: No,,,not a bias valve or a proportioning valve
it`s called a pressure limiting valve cruel Matt...pressure limiting front to rear is also called proportioning (ask ya Dad ![]() ![]() |
Author: | drmini in aust [ Sun Dec 11, 2005 9:53 pm ] |
Not the same thing, Mick.. Rear pressure of this one stays same as front ,until valve moves and locks it off. Not much difference really in pressure setting between S one and others, main difference is S has 5/8" rear wheel cyls not 3/4" so less likely to lock up. |
