tachometers and elec ignition https://www.ausmini.com/forums/viewtopic.php?f=2&t=13914 |
Author: | deleted [ Sun Dec 11, 2005 7:06 pm ] |
Post subject: | tachometers and elec ignition |
I have read once before that tachos from points and elec ignition cars were not compatible. Now that i have honda electronic ignition, will it be a problem using an old smiths tacho, or any tacho? |
Author: | drmini in aust [ Sun Dec 11, 2005 7:46 pm ] |
I'm using a Smiths 8000 tacho on one Pulsar dizzy, and a Veglia Borletti (ex Fiat 124BC coupe) on another. No problem. ![]() |
Author: | Mini Mad [ Sun Dec 11, 2005 8:34 pm ] |
Yeap, the stock smiths tacho in my clubby works fine with the electronic pulsar one ![]() |
Author: | Mike [ Mon Dec 12, 2005 3:55 am ] |
drmini in aust wrote: I'm using a Smiths 8000 tacho on one Pulsar dizzy, and a Veglia Borletti (ex Fiat 124BC coupe) on another. No problem.
![]() Doc are't the loop pickup style tachos incompadre with leccy ign? |
Author: | drmini in aust [ Mon Dec 12, 2005 6:31 am ] |
Yes, that's what Barney has I think. Coil operation is the same, it's just the switching of primary current that is electronic. |
Author: | GT1360 [ Mon Dec 12, 2005 6:47 am ] |
Dont ya just put a resistor or something inline to the tach ![]() |
Author: | drmini in aust [ Mon Dec 12, 2005 6:56 am ] |
GT1310 wrote: Dont ya just put a resistor or something inline to the tach
![]() Clubbies have a loop type tacho and they do work with Pulsar or Honda dizzy. They are just wired in series with primary circuit. |
Author: | Mike [ Mon Dec 12, 2005 7:33 am ] |
Ok ok so more in detail - what needs to be done to be able to run the Smiths type loop type with elec ignition? Or what can be done? |
Author: | drmini in aust [ Mon Dec 12, 2005 7:41 am ] |
On Josh's car, when we fitted a Pulsar, we did nothing- it uses the standard Clubby wiring. ![]() |
Author: | Marvin [ Wed Jan 18, 2006 8:25 pm ] |
Ok so the standard Lucas dizzy is NOT electronic? |
Author: | drmini in aust [ Wed Jan 18, 2006 8:33 pm ] |
Marvin wrote: Ok so the standard Lucas dizzy is NOT electronic?
Correct. Not the antique ones on Oz made Minis, anyway. |
Author: | Marvin [ Wed Jan 18, 2006 8:42 pm ] |
Well it looks like I'll have to get myself a pulsar dizzy to use with my new tacho then ![]() ![]() |
Author: | kazjim [ Wed Jan 18, 2006 8:52 pm ] |
Marvin, no no no.. you can use a Standard Dizzy.. no problem, DOc was just saying it ALSO works woth thepulsar ones.,.... The Tach side of things is exactly the same, but the pulsar Dizzy replaces the points with a doohickie .... the tach stays the same.... and for the record, I've got a Pulsar Dizzy, and a Veglia Tach ....... (Same as Haha) J |
Author: | Marvin [ Wed Jan 18, 2006 9:00 pm ] |
Yes I understand you can use the current tacho with a pulsar dizzy but I just bought a Speco tacho and it says elec ignition so therefore I need to get a pulsar dizzy. It came with a diode to be used with points ignition but I may aswell just get a pulsar one anyway 'cos of all the other good reasons to have one |
