brake drum screw stuffed!
https://www.ausmini.com/forums/viewtopic.php?f=2&t=14004
Author:  monrel [ Wed Dec 14, 2005 7:53 pm ]
Post subject:  brake drum screw stuffed!
I have one more screw to take off in order to remove a front brake drum, but there's nothing for the philips head screwdriver to hold onto anymore!!! Does anyone know the best solution to get these out?
Author:  bnicho [ Wed Dec 14, 2005 7:57 pm ]
What a pain!
Drill the head off with a fat drill bit. Then remove the remains with vice grips once you have the drum off.
Author:  J_A_M [ Wed Dec 14, 2005 8:09 pm ]
or...get a centre punch and 'tap' the head of the screw in an anti-clockwise direction to unscrew it :wink:
Author:  drmini in aust [ Wed Dec 14, 2005 8:11 pm ]
If there's any of the X left in there an impact screwdriver will get it out.
Otherwise, stick a 5/16" drill into it. That will drill the head away, so drum will come off, then use vicegrips on the threaded bit. :wink:
Author:  68matic [ Wed Dec 14, 2005 9:36 pm ]
impact screwdrivers go for about $40. you hit the end of it hard, and it turns
very useful thing to have ray, i recommend getting one
Author:  monrel [ Wed Dec 14, 2005 9:37 pm ]
Post subject:  thanks!
thanks guys!!
will drill into it tomorrow!
vice grips have been my hero lately when it comes to rounded off bolts, but this countersunk screw stumped me :cry:
thanks for your advice!
Author:  awdmoke [ Wed Dec 14, 2005 9:42 pm ]
Buy/borrow an impact driver.
Very satisfying getting that ****ing screw out by using a BFH :twisted:
Author:  Angusdog [ Thu Dec 15, 2005 6:16 am ]
I've never had much success with impact drivers - not to malign the tool, just I never managed to get stuck screws out with one.
A handy tool to have is a T-handled screwdriver, usually sold as hex-ended so you can fit a bit that's exactly the right size. Soak the screw in WD-40 overnight then use all your weight on the end of the screwdriver to keep it in there and turn.
I've also had success with cutting a new slot (for slotted screws) with a cutting disc on a Dremel. Often you need a whole armoury of tools handy to get a job done.
Author:  Lillee [ Thu Dec 15, 2005 10:24 am ]
I lub my impact screw driver :oops:
Author:  KennyKix [ Thu Dec 15, 2005 12:19 pm ]
Ezyout! I had the same problem and used an Ezyout and I had the annoying things (Screws) in my hands in about 5 mins. (2 ea a side)
You can get these ezyouts from hardware shops about $5 - $10 ea. (you only need one)
Author:  h0nk [ Thu Dec 15, 2005 4:05 pm ]
I had the exact same problem last week.. Just drilled the head off it and left the rest in there.. The wheel nuts hold it together.
