which needle for me? https://www.ausmini.com/forums/viewtopic.php?f=2&t=14217 |
Author: | VeG [ Thu Dec 22, 2005 10:40 am ] |
Post subject: | which needle for me? |
ok, so i did a search and couldn't find much so im askin...... Which needle should i have in my 1.5in SU? All thats been done to the car is- LCB's, 1.75in exhaust, an rc40 muffler and a ramflo filter The needle in there at the moment is ADF (standard) Grateful for any help EDIT: the motor is an 1100 ![]() |
Author: | K-Bar [ Thu Dec 22, 2005 12:59 pm ] |
Heya WIN SU suggests u should use BDE and possibly try BEJ BFY |
Author: | VeG [ Thu Dec 22, 2005 1:17 pm ] |
ta, ill give it a go |
Author: | VeG [ Thu Dec 22, 2005 3:32 pm ] |
winsu is severly wrong, B-series needles are for HS6 carbs, i have a HS4. Perhaps not the BDE then...... |
Author: | K-Bar [ Thu Dec 22, 2005 3:39 pm ] |
there is a drop down tab to select needles for the HS4... and thats what i did.. i put ur engine specs through, and it came out with BDE id give it a go |
Author: | Mike_Byron [ Thu Dec 22, 2005 6:01 pm ] |
Unfortunately - although you selected a HS4 carby, the BDE is a needle for the HS6 and HIF range of carbies. WinSu has some development problems at times |
Author: | VeG [ Thu Dec 22, 2005 9:06 pm ] |
thats what i thought^^. Ill keep looking around, might ring a few places and see what happens. |
Author: | drmini in aust [ Thu Dec 22, 2005 9:09 pm ] |
Mike_Byron wrote: Unfortunately - although you selected a HS4 carby, the BDE is a needle for the HS6 and HIF range of carbies.
WinSu has some development problems at times What Mike means is, The BDE won't even go in there, as it's made to fit in a 0.100" jet. Your HS4 has 0.090" jet.....! |
Author: | VeG [ Thu Dec 22, 2005 9:16 pm ] |
yea, i need a needle starting with 'A' from what i gather, not 'B'. someone said an AAN or AAM (cant remember which) would be what i want. |
Author: | gafmo [ Thu Dec 22, 2005 9:53 pm ] |
Give Silvo (Bill Silvertsen) a call at Midel 02 9759 5598 Tell him your spec's and he will lead you in the rite direction ![]() |
Author: | VeG [ Thu Dec 22, 2005 10:23 pm ] |
i might just do that Gaf, im in Adelaide but my fiancee owns her own sales company, ill put it on her bill ![]() |
